Finally Changed 4R100 Filter & Cleaned Pan
We let the pan drain all night like you said. We had right at 6 quarts by morning. It seems like that damn filter holds 10 gallons though, and no matter how we tried to hold it ATF came out. At the end we looked like Charles Manson had paid us a visit. Thanks for the help!
Wow!
Just goes to show that if you change out the ATF at the recommended intervals, you can keep it looking good.
That pan is amazingly clean for that many miles.
Good job.
Here's a thread on my 4r100 with over 300k. You can see the residual on the magnetic. I don't see much of anything on yours.
https://www.ford-trucks.com/forums/1...ng-tranny.html
Good job.
Thanks! I had a friend/master mechanic scare me into dropping pan. He said it would be covered in clutch sludge. We drive mostly on limerick roads, and the bumps would cause that sludge to rise and clog filter prematurely and/or get back into transmission somehow. My retort was, I change the fluid every 30k which should help remove 'some' of the finer suspended particles, I hoped. Then I went further and stated that 'I was informed' that Ford declares the filter is a lifetime filter, 'if' ATF is changed at recommended intervals. He replied that sounds like the response of a company that wants to sell more transmissions.
The metal of the transmission under the pan cover was not at all oxidized and still retained it's new luster. We are very blessed!
Thank again to Mark K. also!
People "bash" the 4R100. Well, they're idiots. Bottom Line: If you maintain them they last! With REGUALR maintenance they'll outlast the vehicle.
The reason we see failures is there were more than 5,000,000 E04D & 4R100 produced.
While they are "maintenance intensive" compared to todays transmissions they were light years ahead when produced. They were the first electronically input transmission for light duty trucks.
I liken vehicle maintenance to a sign I once saw in a Dentists Office 30 years ago: "Ignore your teeth and they'll go away" Same for our Truck Parts.
Thank you! My older son helps me out a lot. It's nice to be able to show him that, like life, if you take care of stuff it pays off 'most of the time.' It nice when you see your hard work pay off ten fold!
Friction is the force that resists the sliding of two surfaces that are touching. Friction in a transmission transforms mechanical energy into thermal energy. Thermal energy is a waste energy. To reduce mechanical energy loss due to friction, we use a lubricant, ATF. The cleaner we keep the ATF, the less friction occurs, which transforms less mechanical energy into thermal energy, and greatly minimizes component wear.
Nice job! Do you tow much? Is your truck is stock? I think it's been clear the killer of these 4R100's is heavy towing and HP upgrades or the combo of both.
The occasional tow/DD mode with scheduled fluid changes like yours, I would expect to see what you found. Not trying to be an a$$, I'm just sayin
If you do extreme towing then the solution is to change the ATF every 20k and have it tested, then adjust to test results. But if your towing weight exceeds guidelines, you will experience premature self destruction due to run-away themal energy and extreme component wear.
