91 F150 AC question
Old Aug 23, 2006 | 02:18 PM
Ol' Blue91's Avatar
Ol' Blue91
Question 91 F150 AC question
My baby is a straight 6 - 4.9L F150 Custom 4x4. She wont blow cold air out. Sounds like the compressor kicks on when i put it on MAX AC, but it never gets cold. Should I try some of that UV dye to look for leaks and if I dont find one is it safe to use one of those self converter kits from NAPA and charge up?
Old Aug 24, 2006 | 06:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 24, 2006 | 11:30 AM
rsulvan's Avatar
rsulvan
have you tried to add freon? When you mentioned conversion I presume you still have R-12. If you want to convert to 134 I would suggest reading up on the process. there are forums dedicated to ac http://www.autoacforum.com/
Hope this helps
Old Aug 24, 2006 | 01:56 PM
jas88's Avatar
jas88
Yeah, you can't just start pumping R134a into your R12 system and expect it to cool.
Old Aug 24, 2006 | 08:11 PM
Van Zant's Avatar
Van Zant
if the compressor is kicking on there has to be at least some pressure in the system. probably just needs a evac/recharge (convert to r134)
Old Aug 25, 2006 | 09:57 AM
Old Ford Guy's Avatar
Old Ford Guy
Exclamation Hvac Basics...
...DO NOT MIX R-12 WITH R-134a!!!
The charge-port fittings on the high-side & low-side are different for each of these refrigerants and mixing these 2 creates a volitale condition!!!
The gauges are refrigerant-specific...there is a REASON for this!
If your truck is a '91 Ford it IS using R134a. Look for a sticker on the accumulater, compessor, or call a parts store.
If the compressor comes on you some have refrigerant in the system. This means neither the high or low pressure cutout switches have been activated. These 2 prevent damage to the system...too much pressure is dangerous and too little means the components are not receiving any oil circulated with the refrigerant!!!
I cannot find ANY DIY kits at ANY parts store that will attach to my '91, I looked at them all, they all $UCK!
Usually for around $100 an EPA certified shop can hook up your system, pull a vaccum on it, do a leak test, and have you on the road in less than 1 hour!!!
For that ammount of cash it IS worth it.
Old Aug 26, 2006 | 12:43 AM
phoneman91's Avatar
phoneman91
[QUOTE=Old Ford Guy]...DO NOT MIX R-12 WITH R-134a!!!
If the AC hasnt been converted--the AC in a 1991 Ford truck was R12. Ford didnt convert to R134a until--about 1994.
Old Aug 26, 2006 | 09:38 AM
Old Ford Guy
Opps...
...your right, my '91 is R12. I was thinking it was my other truck. The rest of the info on refrigerants is correct though.
Old Aug 27, 2006 | 01:51 PM
Ol' Blue91's Avatar
Ol' Blue91
Thanks
You guys are a ton of help!!!!! I am so glad that I found this site. Anymore questions I have I know where to go.
handyandy91
1997 - 2003 F150
Jun 19, 2011 07:00 AM
ac700wildcat
Jun 17, 2010 04:42 AM
Cowboy34
May 16, 2010 09:00 AM
natedog37
May 9, 2010 08:48 PM
