Sponsored by: Auxito
Need help w/ A/C
Old Jun 18, 2011 | 12:56 PM
handyandy91's Avatar
handyandy91
Need help w/ A/C
03 f150 4.2 v-6
My a/c comes on and blows cold but there is a loud clicking coming from the compressor. It just started doing this with a/c on.
Does this mean the oil is low in the a/c system?
What should I do the check this?
I do have a vac pump and gauge set but The system works just goes to defrost when hitting gas hard. Found one vac leak behind battery must be one more somewhere. I don't think the two problems are related.
Any one got any ideas?
Old Jun 18, 2011 | 06:26 PM
steve(ill)'s Avatar
steve(ill)
if it is somewhat constant clicking, it might be a noise in the clutch. If it clicks once a minute or so, it might be the clutch kicking in and out with low pressure switch. Look at the clutch and see if it "stops or starts" turning when the clicking occures, or is the clicking more constant (like clutch damage or air gap/ spring).
Old Jun 18, 2011 | 09:22 PM
handyandy91
With A/C on there is a constant click,click,click,click....... when you turn off A/C the noise stops. Noise comes from compressor. Dose this mean it needs oil added, how do you check A/C oil level/quantity??
Old Jun 19, 2011 | 07:00 AM
projectSHO89's Avatar
projectSHO89
No, it doesn't mean you have to check the level of the oil in the AC system since it's impossible to do in a sealed system.
If you're getting a mechanical clicking from the compressor itself, you like have a compressor that's getting ready to grenade.
vettex2
Nov 25, 2014 08:46 AM
BLADE35
Jul 13, 2013 11:33 PM
SOB Racing
Oct 1, 2012 12:26 PM
vent
1983 - 2012 Ranger & B-Series
Jun 4, 2010 12:51 PM
1990Fordf150v8
13
Jun 22, 2004 01:08 PM
