I just picked up an Acer PC (I know, I know) and have finished setting it up. I dont have any speakers yet but sisnt think that was a problem since I could hear out of the built in speaker right? Problem is, I cant. The only way I can hear sounds is if I plug in a set of headphones. I tried the troubleshooter, to dee if my sound devices were set up correctly and they seem to be. I also checked to see if it was turned way down or muted. Its not. Any ideas?
I dont have any speakers yet. i thought I had some spare ones hanging around, but after I got the pc hooked up I realized they were gone. i thought i could use the little mono speaker that is in most PC's for the time being.
A bunch of Windows 3.1-era systems did have a driver to use the PC speaker, I remember loading it and setting them up. That was back before sound cards were cheap and common. Some of those little speakers were pretty decent, most weren't, and if you can get a case with a built-in speaker at all today, they are crappy.
As jake00 was saying the built in speaker is for motherboard related sounds, it is plugged into the motherboard and gives off beep codes for bios level errors. If you have a sound card or on board audio you could plug this cheesy speaker in to the audio card if you attached the proper jack. The reason that the motherboard speaker is not controlled by a audio card is if you have a board level problem (like a poorly seated memory module) it may halt before the audio card is able to talk to the processor. The reason that this is just a cheap speaker is that all it needs to do is beep.
