Computer speaker help needed
Old Aug 22, 2006 | 07:55 PM
MatthewC's Avatar
MatthewC
Hey guys and gals.
I just picked up an Acer PC (I know, I know) and have finished setting it up. I dont have any speakers yet but sisnt think that was a problem since I could hear out of the built in speaker right? Problem is, I cant. The only way I can hear sounds is if I plug in a set of headphones. I tried the troubleshooter, to dee if my sound devices were set up correctly and they seem to be. I also checked to see if it was turned way down or muted. Its not. Any ideas?
Old Aug 22, 2006 | 08:13 PM
Mil1ion's Avatar
Mil1ion
There are powered speakers which receive an audio signal then the sound is amplified.
They have a power cord to a wall plug.
Or
there are NON-powered speakers that hook up to an amplified connection on the computer which get an amplified audio signal from the computer.
Which ones do you have?
Old Aug 22, 2006 | 08:16 PM
MatthewC's Avatar
MatthewC
I dont have any speakers yet. i thought I had some spare ones hanging around, but after I got the pc hooked up I realized they were gone. i thought i could use the little mono speaker that is in most PC's for the time being.
Old Aug 22, 2006 | 08:30 PM
jake00's Avatar
jake00
the speaker that is usually inside the case? that's really not able to be used at a speaker like you want to use it.
Its for motherboard related sounds
Old Aug 22, 2006 | 08:51 PM
MatthewC's Avatar
MatthewC
My last computer had a built in speaker, and all my games, videos etc...were played on that....
Old Aug 23, 2006 | 07:00 PM
jake00's Avatar
jake00
really, got any pics or specs on this speaker? Im curious
Old Aug 23, 2006 | 09:33 PM
mikebon08's Avatar
mikebon08
A bunch of Windows 3.1-era systems did have a driver to use the PC speaker, I remember loading it and setting them up. That was back before sound cards were cheap and common. Some of those little speakers were pretty decent, most weren't, and if you can get a case with a built-in speaker at all today, they are crappy.
Old Aug 24, 2006 | 10:13 PM
RockyMtnF250's Avatar
RockyMtnF250
As jake00 was saying the built in speaker is for motherboard related sounds, it is plugged into the motherboard and gives off beep codes for bios level errors. If you have a sound card or on board audio you could plug this cheesy speaker in to the audio card if you attached the proper jack. The reason that the motherboard speaker is not controlled by a audio card is if you have a board level problem (like a poorly seated memory module) it may halt before the audio card is able to talk to the processor. The reason that this is just a cheap speaker is that all it needs to do is beep.
Old Aug 25, 2006 | 12:48 PM
andym's Avatar
andym
Like everyone is saying, the built-in PC speaker does not connect to your sound hardware. You need headphones or external speakers.
mark a.
22
Apr 29, 2010 10:06 AM
Mil1ion
19
Jun 27, 2007 12:23 PM
bf250
21
Mar 6, 2007 07:08 AM
ryn6609
17
Apr 18, 2005 07:26 AM
karljay
Mar 1, 2003 10:26 AM
