New shocks?
Old Dec 21, 2006 | 11:47 PM
gabeyd's Avatar
gabeyd
Some other tips.
For the front, remove the top nut, then the bottom bolt, then remove the shock. Reverse for installation. You have to kind of push up the plastic wheel well stuff to get the shock to slip on/off the upper mounting bolt. You don't have to remove it though, just push it up a bit.
For the rear, remove the bottom nut and bolt, then the top two bolts. Install the top first, then the bottom. You'll need a really long socket extension for the top bolts. I had to put three short ones together to be long enough.
Old Dec 22, 2006 | 11:43 AM
afreemanmd's Avatar
afreemanmd
Great, thank you!
I didnt realize there was such a difference between the front/rear!
That should save me a lot of trouble and a chance of stripping out one of the bolts
Isaac
Old Dec 22, 2006 | 08:35 PM
aklim's Avatar
aklim
For the rear, make sure when you put those bolts in the top of the shock you use anti-seize. One of my bolts took out the "nut" with it. So, I'd also have a few of those "nuts" ready in case you break them.
Old Dec 24, 2006 | 09:03 PM
RobertH's Avatar
RobertH
Got the Rancho RS9000X's with the air control system. They are great so far. I like the ability to ride on 0 setting then put them up to 9 when towing or carrying a heavier load.
There was nothing wrong with my factory shocks, but everyone seemed to change their shocks, so it sounded like a good idea. I think they are more stable and I definately like the stiffness when I turn up the setting! Less bounce with the trailer hooked up!
BioBurner
Jul 22, 2008 04:09 PM
big315
May 23, 2007 10:20 PM
big315
Jun 2, 2006 01:12 AM
big315
Nov 15, 2005 04:27 AM
jle249
Nov 16, 2002 05:47 AM
