Sponsored by: Real Truck
Will these shocks work?
Old Jul 22, 2008 | 10:23 AM
BioBurner's Avatar
BioBurner
I have a set of Skyjacker Nitro 8000 shocks (from a previous project). My 02 PSD 4x4 w/leveling kit needs new shocks.
How do you determine what shocks work on modified suspension?
Old Jul 22, 2008 | 12:26 PM
ReAX's Avatar
ReAX
I usually pull out a couple of manufacture's catalogs, find the spec's for the shocks that should be on the vehicle with your lift and compare that to other shocks' specs.
Extended and collapsed length the only numbers you can do much with, unless your shocks are rebuildable. So find your extended and collapsed height, (squeeze them down and measure, then pull them apart and measure.) Then find your application in the book and see if they match up. I would stay with in about an inch of recommended. However, with an average 2" leveling kit, the app guides will most likely recommend a stock length shock.
Old Jul 22, 2008 | 04:09 PM
BioBurner's Avatar
BioBurner
Cool beans. These should work then.
mcali2
1997 - 2003 F150
Dec 14, 2016 11:07 PM
hwybee22
Nov 23, 2016 08:20 PM
EASTSIDEAUTO
Mar 11, 2012 10:21 PM
proudtruck
Jan 8, 2009 10:48 PM
caddywhompus
1978 - 1996 Big Bronco
Jan 12, 2004 08:38 PM
