'01 F150 4.6L, I have a MisFire #8, swapped COP, replaced all 8 plugs with autolite AP764, it ran better for a very short time then started to miss again and after 100 miles or so CEL "Misfire#8" again.
I replaced the plugs with the motocraft same misfire, CEL has not yet came back on but still runs the same.
Then...
I than decided to unplug the wire to #8 injector truck ran a little worse and the CEL came on, I than plugged the #8 injector back in and unplugged #6 injector, truck seemed to run about the same as when I unplugged #8.
I am thinking #8 injector is about 75% shot??? I am going to pick up an injector and a set of o-rings for the other three injectors on that side and see what happens. I wish it was on the other side 1-4 as that #8 is way back in there.
