I just did the front of my fifth wheel. It was REALLY bad. Sitting in the shade I hosed it down a couple times and let it dry then sprayed it with a Sea Foam product called Bug-B-Gone, let it sit ~60 seconds and litterally wiped the bugs off with a water dampened used drier sheet. I'd used it before but added the shade and pre-dampening with the hose and that really improved the performance. Made a really bad job almost enjoyable.
They also make a dynamite! penetrant called Deep Creep. I've used all their products and been impressed with them all. I use their Sea Foam for carb cleaner and fuel stabilizer. Recommend them all.
Where can i find this stuff?? or do i need to order it over the net. looks like good stuff.. thanks for your input.
From the "BUY" tab on their web site:
Where to Buy SEA FOAM
Sea Foam is not sold online, but we would be happy to help you locate your nearest dealer. Please email us your address at customerservice@seafoamsales.com.
SEA FOAM can be found in many of the following auto parts stores:
ABC Auto Parts
Advance Auto Parts
Auto Value
Bumper to Bumper
CARQUEST Auto Parts
Midway Auto Supply
NAPA Auto Parts
O'Reilly Auto Parts
Parts Plus
PEPBOYS Auto
Pronto Auto Parts
Many independent auto parts stores also carry SEA FOAM products. Please contact your local auto parts store to see if they carry SEA FOAM products.
All the stores listed have active links on the page.
Just remember, if you've got clearcoat paint and you see color on your polishing/waxing cloth, you're DONE......or should I say the paintjob's done. You've buffed/waxed/polished your way down to the base coat....very bad!
