Bug Remover
Old Jul 28, 2010 | 05:08 PM
Arn's Avatar
Arn
Bug Remover
Not really Ford specific, but what do you all use to remove bugs from your plastic mirrors, bug deflectors etc. I just had my truck detailed & they got all of the road grime & bugs off. My bug remover is not safe for plastic so what works?
Old Jul 28, 2010 | 05:32 PM
Coskid's Avatar
Coskid
I have used a few products in the pass but for the most part some water, soap, and a little bit of elbow grease takes them off for me.
Simple Green is what I used to use and it worked pretty good.
Old Jul 28, 2010 | 05:52 PM
n5926g's Avatar
n5926g
+1 on the simple green...after you have all the "stuff" off,coat the plastics with some Pledge furniture polish.It keeps them from sticking too bad,and actually keeps some from sticking at all.I used this trick on my Plane windscreen,and leading edges of the wings...worked like a charm.
Old Jul 28, 2010 | 07:23 PM
aquaholic2's Avatar
aquaholic2
Dryer sheet..... Spray a little water and work it,rinse and done.
Old Jul 31, 2010 | 06:03 AM
60DRB's Avatar
60DRB
WD40, works on tar too.
Old Aug 1, 2010 | 12:14 AM
elite64a's Avatar
elite64a
I'll second the dryer sheets they're awesome!!
Old Aug 2, 2010 | 09:58 AM
jetdoc7's Avatar
jetdoc7
I use one of the scrubbies that are made for Teflon Pans. Dip it in the wash water, and scrub lightly on the front end. Gets rid of the bugs, and you can go back over the area if need be.
Old Aug 4, 2010 | 09:59 AM
wildcard30's Avatar
wildcard30
Simple Green. It's all I use. Apply full strength. Let it side for a minute. Scrub with a bug remover pad. If it didn't all come off, do it again. I use it on tar and bugs.
Ralph
2009 - 2014 F150
Apr 2, 2012 08:49 PM
gascan
6.7L Power Stroke Diesel
42
Dec 6, 2010 03:28 PM
REDFORDFX4
2009 - 2014 F150
16
Jul 6, 2010 08:02 PM
Oxxon
2004 - 2008 F150
21
Mar 30, 2009 01:03 PM
derherr65
Apr 11, 2007 11:25 PM
