Sponsored by: Real Truck
Vibration at 40 mph?
Old Aug 19, 2006 | 01:51 PM
Gale Boak's Avatar
Gale Boak
Smile Vibration at 40 mph?
I have a 1997 Ford f-250 7.3 diesel short bed. I use it for hauling my 5th wheel mostly. I get a vibration at about 41mph and it stays until you get to 45 mph.The transmission is fairly new and the tires are 1 year old. Anyone have a idea what could cause this? Thanks for your time.
Old Aug 19, 2006 | 05:17 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE. Every time I've had to deal with a vibration at a certain speed it has ended up being the u-joints in the rear axle.
Old Aug 20, 2006 | 03:06 PM
whomrig's Avatar
whomrig
Hi, is the vibration different loaded or empty?
Old Aug 20, 2006 | 09:57 PM
Apache's Avatar
Apache
Never heard of U-joints in the rear axle. Do you mean in the rear driveshaft?
Old Aug 20, 2006 | 11:23 PM
ddubya61's Avatar
ddubya61
My buddy had the same problem. He had the u-joints and the carrier bearing changed and it is gone.
Old Aug 21, 2006 | 08:31 PM
cookie88's Avatar
cookie88
FTE Emeritus
Of course that's what I meant. Thank you you pointing out my brain fart.
Old Aug 25, 2006 | 03:06 PM
gilchris's Avatar
gilchris
Had the exact same problem with '05 PSD S/D, S/C long bed. Dealer finally replaced the entire drive shaft assembly, including U-joints. Problem solved. Thankfully it was a warranty job or it would have been "big bucks!"
henry bigham
Oct 9, 2015 11:11 AM
mr.noodi
Dec 9, 2013 11:39 AM
thebandit343
May 2, 2013 03:23 PM
CrazyMiracleMan
1983 - 2012 Ranger & B-Series
19
Dec 15, 2011 11:30 PM
Chargerkid
May 2, 2004 04:13 PM
