Another challenge question...
Old Aug 19, 2006 | 01:32 AM
MrSki's Avatar
MrSki
So how many years was it I asked to be stumped?
I got stupid responses like who won the 1953 world series? Well my Grandapa is dead but I'm sure he knew.
Any real world questions about Gen 1 Explorers? Bring it on!
Old Aug 19, 2006 | 10:55 AM
Backin72's Avatar
Backin72
Does Jharger like skiing?
Old Aug 19, 2006 | 11:03 AM
aquanaut20's Avatar
aquanaut20
Is there an easy way to access the oil pump/remove the bottom pan on a 92 4.0 OHV engine
Old Aug 21, 2006 | 01:26 AM
MrSki's Avatar
MrSki
Do ya think?
Old Aug 21, 2006 | 01:29 AM
MrSki's Avatar
MrSki
Actually - that is a good question. Apparently the Ford dealer changed my pan gasket out 2 different times under warranty for leaks. I can not believe they pulled the motor to do this since both times it was in and out the same day. Maybe some suspension components need to be dropped...but I would think you can pull the pan with the motor in place.
Either way, I would first change out my O2 sensors before I did anything else....
Old Aug 21, 2006 | 10:20 AM
aquanaut20's Avatar
aquanaut20
MrSki,
So you are already stumped, you dont know how.
Q. why would I want to change out the O2's when I am asking about the oil pump/pan removal...
Old Aug 21, 2006 | 05:59 PM
MrSki's Avatar
MrSki
Aquanaut - if you can't see an inside joke when it's right in your face then I can't be sucsessful at explaining it to you. Right now Backin is rolling on the floor laughing...
Old Aug 21, 2006 | 07:27 PM
aquanaut20's Avatar
aquanaut20
so while he on the floor LHHO, have him roll under the truck and change out the o2's
Old Aug 22, 2006 | 11:00 AM
MrSki's Avatar
MrSki
The purpose is to shake out those "well I think it's a stupid question so I wont ask" questions.
Something like, there's a oil leak somewhere...looks like the oil filter...but I change the fliter, new gasket...still leaks, any ideas?
Maybe 10 other guys out there have the same issue but didn't think twice about it. Might be as simple as new o-rings on the oil filter adapter...which is hard to see and behind the exhaust manifold.
Oil pan removal is a good question. I also want to know how to remove it with the engine still in place. So if anyone knows...pipe up!
Old Aug 22, 2006 | 09:30 PM
aquanaut20's Avatar
aquanaut20
'Aquanaut - if you can't see an inside joke when it's right in your face then I can't be sucsessful at explaining it to you. Right now Backin is rolling on the floor laughing..."
With comments like this you are not going to get any of those shy contributors.
27 yrs in LAW enforcement and 3 as a CORONER, I have thick skin, so your comments didnt bother me.
MRSKI, Just so there is no doubt, I have seen brighter stars in the morgue.
Old Aug 23, 2006 | 12:00 AM
MrSki's Avatar
MrSki
Kind of explains a lot about you attitude then....
tcjhkbjt
Apr 28, 2014 03:56 PM
67nukeford
Nebraska Chapter
Mar 26, 2014 08:17 PM
Talyn
Michigan Chapter
35
May 26, 2010 07:57 AM
PAVEMENTMAN
Dec 25, 2009 07:54 PM
new2dsl
May 1, 2004 09:12 AM
