99 EB Going nuts!!!!!!!!
Old Aug 18, 2006 | 07:31 PM
anjanzo's Avatar
anjanzo
Unhappy 99 EB Going nuts!!!!!!!!
Hi,I need help with my 99' Exp. EB, when I remove the key the radio stay on and the AC panel blinks like crazy in addition I closed the truck and the AC turn on and off by itself with no keys on the steering wheel!!!! , also I noticed when I move the handle on the steering wheel from Parking to Drive the radio switches from off to on and viceversa, any ideas?
Old Aug 18, 2006 | 08:55 PM
FTE Herman's Avatar
FTE Herman
Welcome Anjanzo! When we see electrical issues such as this we tend to look at the
Old Aug 19, 2006 | 02:23 PM
anjanzo's Avatar
anjanzo
Hi hkiefus ,I don't understand your answer, can somebody help me?
Old Aug 19, 2006 | 07:43 PM
FTE Herman's Avatar
FTE Herman
I'm sorry, it appears that I didn't finish... we tend to look at the GEM (Generic Electronics Module), which should be on top of your fuse panel (the one under the steering wheel). Generally, water gets to it through a windshield leak and crazy (full moon type of) things start to happen.
Old Aug 20, 2006 | 09:10 AM
anjanzo's Avatar
anjanzo
Thanks I will check that today to see what happened.
Old Aug 20, 2006 | 09:57 PM
JayS's Avatar
JayS
I'll second that. My neighbors did the same thing. That windshield leak drains water directly onto the GEM and when that starts shorting it can cause all kinds of gremlins to pop up.
Old Aug 23, 2006 | 04:25 PM
eb20004x4's Avatar
eb20004x4
Mine did many of those things for several days then my battery died. Replaced the battery and all the demons have apparently been exorcised and that was a couple of months ago. Last time I had to replace the battery (about 3 years ago) it was preceded by wildly fluctuating gauges. YMMV
Old Aug 24, 2006 | 03:59 PM
anjanzo's Avatar
anjanzo
Ok people check this out , I talk to an electronic tech. and he told me that sometimes the GEM on a car stays "on", like energized, so I disconnect the fuse that work for the radio and the GEM and presto!, the problem is gone, hopefully is fixed forever.
jrclark6
Feb 9, 2017 03:05 PM
abe
Dec 22, 2016 08:14 AM
Rusty_S
2015 - 2020 F150
16
Jan 25, 2016 01:09 PM
sefuller
Jan 30, 2006 06:24 PM
