99 Expedition Accessory delay?
Old Jan 1, 2005 | 08:41 PM
sefuller's Avatar
sefuller
The manual for my 99 EB Expedition states that the windows and radio should operate for 10 minutes after the key is removed or until a door is open. The windows work as adverstised, but the radio goes off immediately when the key is removed. Is there a way to turn the feature on and off for the radio, or is there a problem somewhere?
Thanks,
Scott
Old Jan 2, 2005 | 12:34 AM
austinjorg's Avatar
austinjorg
Smile Windows/Stereo
I've got an 03/EB/5.4/2wd, Mine after removing the key the windows and stereo work intil a door is opened.
Hope it help!
Jorg
Old Jan 2, 2005 | 04:42 AM
trike1946's Avatar
trike1946
My 99 works until the door is opened too. I never waited 10 minutes to see what happens then. But the radio works as well as the windows.
Old Jan 4, 2005 | 10:32 AM
elbuencarlos's Avatar
elbuencarlos
I have an Expy 99 also and the delay accesory has never worked as the manual states. I always though that the 99 supoused to work this way, but since trike1946 has a 99 also working fine, then I will start to look for the fuses to see if everything is OK.
Old Jan 4, 2005 | 12:57 PM
willica1's Avatar
willica1
SEFULLER,
Mine does the same thing yours does. Windows work but not the radio. Mine is an XLT not an EB. Maybe that is the difference.
Old Jan 4, 2005 | 02:05 PM
elbuencarlos
I don't think that is the problem, my is an 99 EB.
Old Jan 25, 2006 | 12:31 PM
Berggy's Avatar
Berggy
My 99EB is the same ... windows etc works ... but no radio ... anyone know a cure?
Old Jan 25, 2006 | 04:15 PM
pitrow's Avatar
pitrow
I'm in the same boat... windows work, but no radio. I'm curious to see how this turns out.
Old Jan 25, 2006 | 08:32 PM
Sprung's Avatar
Sprung
I remember reading another thread like this earlier and someone said it has to do with teh Speed Sensitive Volume. If you have it ON, the delay doesnt work. I havent tried, but worth looking into.
I'll dig and see if I can find that post.
BD
Old Jan 26, 2006 | 10:39 AM
pitrow's Avatar
pitrow
Hmmm that could be. I do have the SSV turned on.
Old Jan 27, 2006 | 09:56 PM
doug_miami's Avatar
doug_miami
For the 99 model year, only the "Super Sound" audio system has the radio powered by the accessory delay (it is a relay that is controlled by the GEM and located in the interior fuse panel). All other audio packages have the radio powered by the ignition switch. If you don't have a factory subwoofer, you don't have the "Super Sound" system (now called "Audiophile") and your radio will turn off when the key is turned off. If there was something wrong with the accessory delay relay, the power windows (and possibly radio- if you have "Super Sound") would not work at all. Hope this helps.
Old Jan 30, 2006 | 06:24 PM
Sprung's Avatar
Sprung
Hmmm.. I have the Factory Sub, and I DID turn the SSV down to 0 (didnt see OFF) and still no radio after removing keys. Windows do work with key out. I'm not that worried about it since when I pull my key out, I'm leaving the truck.
BD
ExplorerTominCO
Oct 22, 2016 10:02 PM
fishmon1
Jan 12, 2015 09:40 AM
jeepzj94
Mar 5, 2011 08:13 PM
Matt M, PA
Feb 14, 2005 09:00 AM
Luzer27
Dec 27, 2004 09:51 PM
