Hidden Deck Fasteners
Old Aug 18, 2006 | 08:57 AM
Bruker's Avatar
Bruker
Question Hidden Deck Fasteners
I going to be replacing my treated wood deck with a 5/4 composite deck surface and I'd like to use one of the many new "hidden deck fastening methods". Has anyone here ever used on of these methods and what do you think about them?
Old Aug 18, 2006 | 04:58 PM
OhSoBlue's Avatar
OhSoBlue
I have never used them in the many (7-10) decks I've built but have been on a couple of composite decks and them seem very nice. The only bad I've heard is they are very slippery when wet or snow covered, not that you live where there is snow or that you'd be using the deck in the winter if you did live where there is snow. I generally always go with the treated lumber for the frame work and deck with cedar. Cedar also can be slippery, I guess its just how a person walks on it and when. Good luck.
Old Aug 18, 2006 | 08:23 PM
Ford79's Avatar
Ford79
I used them on my aunts deck with composite decking(Ultradeck Solid) The ones we used are called "Tiger Claw". I should have used them on my cedar deck.
Old Aug 19, 2006 | 11:03 AM
jake00's Avatar
jake00
we used the eb-ty system on my parents ipe deck, It sucked
Old Aug 19, 2006 | 03:19 PM
Bruker's Avatar
Bruker
Why didn't they work? What went wrong?
Old Aug 22, 2006 | 01:22 AM
-Mike-'s Avatar
-Mike-
Did my own version 2 decks ago. All I did was buy 1.5" x1.5" x 1/8" aluminum angle and screw it to the side of each joist at the top to act as a flange to screw the deck boards down from the under side. It worked out well, and it had a neat look to it if you were the type of person to notice there was no screw heads on the deck. 98% of people didn't notice a thing. If I were going to do it that way again, I'd paint the top of the aluminum angle brown to hide it a bit. When the sun was at the right angle it was very easillly noticed through teh seams.
Old Aug 22, 2006 | 05:46 AM
wiseguy's Avatar
wiseguy
I used Deckmaster, and was really satisfied with them. McFeeley's on the web carries them.
Old Aug 22, 2006 | 06:32 AM
jroehl's Avatar
jroehl
Ipe is very, very hard. I'm guessing they destroyed the fasteners trying to get them into the ipe.
Jason
Old Aug 22, 2006 | 06:41 PM
jake00's Avatar
jake00
its more the woods fault than the fasteners, the wood shrank and popped out, I think the "clips" were large enough to secure the wood during expansion/contraction
Old Aug 22, 2006 | 07:37 PM
Greywolf's Avatar
Greywolf
I would likely use the new and improved "GYAUI" method...
"Get Your A** Underneath It"
Also known as "SCREW UPWARDS". Lag bolts ought to do the job...
Aftrmidnite
Dec 21, 2009 10:53 AM
Flexfuel-Dave
21
Feb 5, 2009 10:43 AM
rellik74
18
Jan 5, 2007 04:57 PM
Greywolf
21
Jan 6, 2006 06:23 PM
christop43
17
Mar 20, 2002 07:35 PM
