BTS Valve Body = sluggish reverse?
well, got a '00 F350, CC LB 7.3 AT 4x, recently installed a BTS VB along with a new filter. So, since doing that my truck is very slow in reverse, like your slipping the clutch, or it's in low range. It seems more prevalant when the truck is warmed up, but not sure about that... I only back up twice, first is downhill and the truck is allready warm the second time. I checked my fluid and it looked good, I'll try again in the mornin when it's good and warm.
Thanks for any input!
That doesn't sound normal. I just recieved my bts valve body and going to put it in this week. Hope that mine doesn't do that. I would call brian or cal, they have been extremely helpfull with me and from what i read on this site bts stands behind their work and should fix the problem for you. Goodluck
Originally Posted by bhiggins
also did you take the thimble screen out before you put the transgo plate up there?
I did remove it, but the returned it to it location on reassembly. I guess I didn't understand the proper way to install it, I just held it up and trapped in with the valve body, didn't turn and lock it in. Maybe this is part of my problem?
Didn't get a chance to call BTS today and I'd like to talk to them before I drop the pan and waste a case of ATF, so guess I'll wait till monday to proceed. If anyones had this problem chime in, I need some help, don't wanna cook my tranny!
I just sent you a private message with a link to guzzle's install of the bts valve body. Just in case you read this before the message here it is again. http://guzzle.rbmicro.com/bts.html
