Offroad & 4x4
2x4 to 4x4 Conversion Questions
Old Aug 17, 2006 | 09:47 PM
Zed's Avatar
Zed
Have an 81 F150 2x4 to convert to 4x4. (c6 tranny)
I have read the article on this site but have more questions.
1. - Are here differing transfer cases from 80 -96 that can be used and if so what are the differences - pros & cons.
2. Regarding the front axles; any changes through 80 - 96 that are prefered amongst these years.
Thanx in advance for your input
Old Aug 18, 2006 | 12:14 AM
fishmanndotcom's Avatar
fishmanndotcom
well for the C6 you will need the adapter and the corresponding tailshaft. for the longer adapter (8.75" IIRC) you need the longer tailshaft. and respectively for the short adapter (8.75") the short tailshaft. bolting up any of fords t-cases from ~75 to 96 will pretty much bolt in. i believe they all have the 6 bolt round pattern. the NP205 will be your strongest option but low range sucks on those so something like a 1356 gives a super low range with pretty good durability.
if you're gonna do the swap do it right.... find a Dana 44 from a 79 or earlier F150/100. they utilize a solid axle with coils so they are easy to setup and ride nice.
-cutts-
Old Aug 18, 2006 | 12:41 AM
Zed's Avatar
Zed
Where can I find info relating to the versions of t/c's that came in a particular truck? Is there a code on the door jam sticker or is it down to visual recognition of the T/C ?
Could you further explain the advantages over the independent front axle system.
Thanx
Old Aug 18, 2006 | 02:07 AM
fishmanndotcom
here is a place to start, this will give you a rough idea of all the tc's out there
http://www.offroaders.com/info/tech-...rans/trans.htm
http://truckparts-specialists.com/ca...ture-index.htm
http://www.drivetrain.com/transfercasevehcrossref.html
the solid axle will be easier on tires, easier to setup and maintain, cheaper to lift/modify/clean/inspect
-cutts-
10strokin
21
Oct 27, 2015 11:18 AM
BuickBrian
WTB - Parts & other
Nov 17, 2012 11:15 PM
mike manglos
Aug 28, 2008 08:39 AM
Firefighter8-1
Offroad & 4x4
21
Sep 5, 2004 08:54 PM
jaimalade
Jan 25, 2003 05:12 PM
