Back up sensor question/problem
Old Sep 13, 2006 | 02:19 PM
vettdvr's Avatar
vettdvr
Ok,, I have a malfunction question. Mine as in previous post has the light on indicating the system is off even when I depress the button. Is this a normal failure mode or is this what happens when a sensor fails. Thanks Jim
Old Sep 13, 2006 | 04:10 PM
Bill_T's Avatar
Bill_T
LOL at Marks brief reply...
as for vettdvr... When my sensors began failing I had the same symptom of the dash switch not seeming to work properly..
As for the 'hard *****' described by aklim <barely stiffling a laugh> yes the sensor will "see" a hitch in many cases.. depends on hitch itself in terms of length and heigth relative to sensor <ok Mark, go ahead lol>
Bill
Old Sep 13, 2006 | 04:18 PM
vettdvr's Avatar
vettdvr
Bill let me see if I have this right. If a sensor fails the light will stay ON? and you can't turn it off with the button? Is this correct?
Also if it is a sensor is there a way to check just one? thanks Jim
Old Sep 13, 2006 | 09:22 PM
mcamalong's Avatar
mcamalong
Originally Posted by Bill_T
mcamalong
now thats interesting.. they are working in every instance they are NOT supposed to and not working in the 1 situation they are!
did this problem happen all at once or were there other symptoms going on over time?
Well it all started when I had the securty module replaced by the dealer $575.00 ouch!! when I picked it up it started doing this. Of corse the dealer said it is not related. I find it hard to belive because it started before I got of the dealer lot.They would like me to agree to 2 hours labor to check it out. I have already given them to much money. I would like to try to figure it myself with the help of any one who reads these posts. Thank you mike
tcjhkbjt
Mar 10, 2014 09:55 AM
Rozco
Sep 15, 2009 08:51 PM
AltaEx
May 29, 2008 04:10 AM
Turtlesplatter
2004 - 2008 F150
May 18, 2007 08:34 AM
JTATMAN
Jan 15, 2007 10:33 AM
