I've been pondering the idea of converting my stock steering setup to a x-over setup, but i'm not sure if my first idea is safe. I was thinking of turning the stock draglink around so that the hole for the driverside tie rod was down by the passanger wheel and then getting either another draglink or a really long tie rod to connect into it and go back to the driverside.
I'm never putting big enough tires on my truck to warrant doing a SAS, and I like the TTB except for the bump steer, so thats how I came upon this thought.
I'm not 100% sure, but I don't think it would work because the steering setup has to be able to pivot at the same point the axle does. Maybe somebody else could shed some light on this subjest.
no traditional x-over steering will not work. especially if u off road the truck, being as each side moves independently of the other a solid bar will cause the apposing wheel to move when the suspension does. causing a lot of unwanted movment while driving. even on paved surfaces it will cause the wheels to toe in and out as the suspension moves destroying your tires. and possibly other things. i would highly advise agains it.
On the TTB, each side of the axle moves independently of the other, making it necessary for the steering linkage to do the same. On the solid axle, the linkage can go straight across for crossover because the axle doesn't pivot in the middle. It's hard to explain, but if you take a good look at diagrams of both set ups you will see what we're trying to say.
I'm with you on wishing there was a better steering setup for the TTB. Thats the main reason I did the sas on my 94.
Superlift already makes this setup... check out their Superunner steering steup for TTB trucks. The geometry IS better and your idea is sound. The "bump-steer" associated with the TTB is all but eliminated with the Superunner setup. However, it requires that the truck be lifted a minimum of 4" via the suspension. Now, the whole reason that the lift is required is because when Superlift designed the system, the idler arm for the center drag link is mounted to the axle pivot drop bracket on the passenger side of the truck. If you can figure out how to fabricate a mount for the idler arm and keep the susepnsion at the stock height, you are on to something! http://www.superlift.com/accessories/superunner.asp The PDF instruction file details the way the system mounts to the truck. Might be worth a look to see how it could be modified to work on an unlifted truck.
Yea, I would say your bump steer would get worse, not better. As far as the super runner system goes, I looked at one installed and it didnt look much better than the stock setup. The owner said it worked a little better.
Superunner Steering system: It puts the steering linkage pivot points much closer to the axle pivot points through a greater range of steering motion which alleviates the bump-steer condition. Its geometry folks. When the pivots in the steering linkage and the pivots for the TTB axle halves are better aligned with each other during steering maneuvers, the bump-steer goes away.
The Superrunner system is poorly designed at best. All it does is makes the toe change a little more even between the two wheels.
The passenger wheel already has pretty good steering geometry from the factory. It's the Drivers wheel that suffers the most from bumpsteer. The Superlift kit does improve the steering geometry for the drivers wheel a bit. BUT, it takes the steering geometry for the passenger wheel from good to terrible.
A common misconception is that the steering pivot for the coresponding tie rod should be directly in front of the beam pivot. This is not true. Ideally, the radius arm, beam and steering pivot should all intersect the same line.
Here's a pic to illustrate what I'm talking about:
Ideally, the pivot points in the steering system will remain in phase with the location of the axle pivot points or the bump-steer condition will still be there. However, since the ONLY way to achieve that would be to make the steering fully hydraulic the best anyone can hope for is to place the linkage pivots so that when the steering is hard-over the pivots are as close to being aligned with the axle pivots as possible. This means placing them so that they stay as close to the location of the axle pivots as possible throughout the entire range of steering motion. The misconception is that the only time the pivot locations matter is when the truck is pointed straight ahead.
If you're saying that ideally the steering pivots would stay in phase with the axle pivot AND radius arm pivot then I completely agree. But, it isn't necessary.
If you're saying that the radius arm pivot can be ignored and that you only need to worry about the axle pivot then we're on opposite sides here. I've seen a lot of trucks with the steering pivots directly in front of the beam that had a ton of bumpsteer.
My truck spends more time close to centered or "straight ahead" than full lock. Personally I want the geometry to be ideal in the straight ahead position and not at full lock where it spends very little time.
I just thought of something. If you're saying to place the steering pivot (Let's use the passenger beam for example) in front of the axle pivot at full right lock. then we might be saying the same thing in a round about way. when you return to "straight ahead" the steering pivot is back to where I was suggesting which was intersecting an imaginary line drwan through the radius arm pivot and axle pivot.
For the sake of our discussion maybe you could clarify what you mean by "in phase with the location of the axle pivot point".
