Need king pin dimensions please
Old Aug 16, 2006 | 01:14 AM
laynrubber's Avatar
laynrubber
I read my manual and all it says is too use reamer tool but it doesn't tell me the dimension to ream the new bushing to.
My question is how much clearance should the new pin/bushings have, .002", .005" ????
I have tools to ream the bushings.
Old Aug 16, 2006 | 04:56 AM
4tl8ford's Avatar
4tl8ford
Try looking the the rear of the Shop Manual under Specifications.
I think thats where the info is for my 48.
Old Aug 16, 2006 | 07:56 AM
CharlieLed's Avatar
CharlieLed
My 53 manual says to use reaming tool number "T53T-3110-A" to ream the new bushing to the proper bore. Not much help there...the spec sheet however states that the min ID for the bushing is 0.861 inches and the min OD for the spindle bolt is 0.859 inches. I'll leave it to you to decipher but it sounds like the maximum allowable clearance is 0.002 inches.
Old Aug 16, 2006 | 08:47 AM
Randy Jack's Avatar
Randy Jack
CharlieLed's dimensions tell us that .002 is the MINIMUM clearance you should have. That most likely means that .005 was the nominal. Shoot for .002-.005 and you should be good.
Old Aug 16, 2006 | 02:25 PM
laynrubber's Avatar
laynrubber
.002" sounds like a good clearance.
Away i ream
Thanks
tiger100
17
Jul 30, 2015 07:11 AM
VCF3
Feb 4, 2015 09:01 PM
jvmcc
May 24, 2014 04:18 PM
1959_f100
Jun 4, 2009 01:14 AM
cujo8
Aug 18, 2006 06:59 PM
