Simple Green
Old Aug 11, 2006 | 02:47 PM
amg26zephyr's Avatar
amg26zephyr
4wd Low
Simple Green
Hi all. Has anyone tried simple green as a parts washer fluid??? If so, straight up or diluted?
Old Aug 11, 2006 | 02:56 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I've used something similar, I used Greased Lightning, undiluted. I had some engine brackets with 1/2" of 30 year old crud baked onto them, I soaked them overnight. Everything came right off, including the paint. I do recommend wearing gloves with the stuff though, about a day and a half later the skin on my hands started to peel.
I have a benchtop parts washer. I fill it up with Greased Lightning and clean whatever it is I need then I transfer the liquid back into a plastic storage container.
I like it because its cheap, easy, and non flammable
Bobby
Old Aug 11, 2006 | 04:11 PM
AXracer's Avatar
AXracer
I use Simple green for a lot of cleaning, from counters to heavy duty chassis gunk. I dilute it quite a bit for the former and use it straight for the latter. I put it straight in a spray bottle that has choice of spray or stream delivery for parts and chassis cleaning.
If you mean in a recirculating parts washer, I think you would be happier with a solution designed for that purpose, the SG has detergent in it that would require a water rinse.
Old Aug 11, 2006 | 05:35 PM
amg26zephyr
4wd Low
Thanks guys. It is for a recirculating parts washer. I used to get the stuff at ACME, but now they don't stock it. Guess it's special order time.
Old Aug 11, 2006 | 06:39 PM
AXracer's Avatar
AXracer
Try your local NAPA store or whoever is the largest parts provider to pro mechanics, they should stock parts washing solvent or can order it for you. Northern Tool also lists it in 1 and 5 gal quantities. If flamability (low risk) or fumes (stinks) isn't a major concern, just go to your local gas station that has a Kerosene pump.
Old Aug 12, 2006 | 07:33 AM
tomoto's Avatar
tomoto
put 1 Qt of ammonia to a gal of simple green ,it makes a much better cleaner
Old Aug 12, 2006 | 08:41 AM
HOTRODSURFER's Avatar
HOTRODSURFER
ive used simple green and greased lighting-greased lightning is the best,for heavy grease/grime i use it undiluted! but most of the time use 50/50 mix
Old Aug 12, 2006 | 10:04 AM
imlowr2's Avatar
imlowr2
For some reason, I can't stand the smell of Simple Green. Not only that but my parts seem to have this greasy film on them even though they are clean. I found this degreaser at the local 99 cent store that actually my grandfather got me hooked on this stuff. It's called AWESOME, yeh, I know, I had to laugh too. This stuff works! I use it for leaks on my garage floor and everything. You spray it on and it desolve grease quick, then you wipe if off. It doesn't have a strong odor or have an oily film. I buy it by the gallon size now. Can't beat the price either.
Old Aug 12, 2006 | 10:15 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Harbor Freight sells an aqueous cleaning solution for recirc benches. Haven't tried it myself. I like the Purple Power stuff they sell under the AutoZone label, just like the purple Castrol stuff but $3/gal cheaper. WalMart sells it too.
Old Aug 12, 2006 | 11:14 AM
51ford fan's Avatar
51ford fan
Years ago when I worked in a factory we used to mix that orange citrus cleaner with Stoddard Solvent to clean the engine and drivetrain on Forklifts, It worked great. I haven't tried simple green for cleaning, I just use that 99 cent a can engine cleaner and it works well on my Flathead.
Rod 51F1
Old Aug 12, 2006 | 07:34 PM
fiddysixF's Avatar
fiddysixF
Want to clean the bejeebers out of something like suspension parts for example? Use Easy-Off oven cleaner. Careful around rubber though, it eats it!
Old Aug 12, 2006 | 11:44 PM
AXracer's Avatar
AXracer
Eats Aluminum as well.
Old Aug 13, 2006 | 09:26 AM
fiddysixF's Avatar
fiddysixF
True. The little bit I've ever used it around aluminum though, its never been a problem as I was able to clean it off right away. Rubber seems to just keep disolving though. Even after you try to clean it off.
Old Aug 15, 2006 | 08:45 AM
amg26zephyr
4wd Low
I ended up driving to the NAPA distribution warehouse to get their parts cleaner (827-5544 replaces BK 8272544). Expensive stuff though, lists at 119.00/5 gal; luckily I was able to grab it at wholesale cost. I'll let you know if it's worth the dough when I get a chance to clean the sludge out of my drum and try it.
Old Aug 15, 2006 | 01:48 PM
Okiedokie's Avatar
Okiedokie
A well respected older machinest/old car guy had a pan of cleaning solution on his cleaning table that he always used to clean any greasy parts. When I asked him what it was he said "Stoddard Solvent", I asked where to get it and he refered me to a local chemical supply house. When I went and asked for it, they said they did not carry it, but they could sell me some mineral spirits. I, of course told them that I only wanted the solvent. When I related the story to my machinest friend he chuckled out loud when he told me it is the same thing. I have used it every since. Works great and leaves no resisdue. Joe
