I have both. The 9" has a 3.50 gear and the D60 has a 3.54 gear. I am going to be getting a locker and was curious about the strenght of the two? Also, any suggestions on the differential?
The D60, it is a lot easier to change the axle shaft if you break it while using the locker, it is easier to run 16.50 rims, and you can run bigger tires with a load. If you are running 33s or smaller on a 1/2 ton truck, that sees mostly street use then I probably would stick with the 9 inch.
