Codes
Old Aug 15, 2006 | 04:06 PM
rhoadc's Avatar
rhoadc
Codes
Is there a way to pull the codes off of a 2002 Explorer (SOHC) w/o using a scan tool? I dont have a manual and the truck turns over but wont start. Would like to pull the codes so I have a place to start.
Thanks in advance.
Old Aug 16, 2006 | 05:11 AM
marragtop's Avatar
marragtop
Can't help with pulling the codes, but if you turn the key to the ON position, you should hear the fuel pump prime for a second or 2. If not, you have a fuel problem. Start with the fuel pump relay.
Old Aug 16, 2006 | 08:32 AM
Mr.Novice's Avatar
Mr.Novice
One time I had that problem and I only had a fuse that was out. Hope it's that simple for you too. Nobody likes to drop a fuel tank...
Old Aug 16, 2006 | 08:35 AM
marragtop's Avatar
marragtop
Good point on the fuse. The fuel pump should be the very last option.
Old Aug 16, 2006 | 01:15 PM
rhoadc's Avatar
rhoadc
I can hear the pump whine. Today she said then when she tried to styart it yesterday she heard a loud clunk and then it wouldnt start, just cranked over. I blew out the MAF sensor and let it sit for a bit. Then I cranked it over with the throttle to the floor and if started up like it had flooded.
Old Aug 16, 2006 | 01:30 PM
Mr.Novice's Avatar
Mr.Novice
I would go ahead and buy a scan tool if you have a Check Engine Light. It will save you money in the future. If it's not urgent, you can get a cheap one on eBay for less than $30.
Of course, if you can start it now (and you're sure you can start it again), take it up to Autozone or whatever you have locally and they should be able to pull the codes for you.
Old Aug 16, 2006 | 02:51 PM
MrSki's Avatar
MrSki
When you hold the thottle all the way down and crank it over, the PCM does not open the injectors. This is the procedure for starting a flooded engine. It is an engineered solution that is not listed in the owners manual.
pin8246
Jul 21, 2012 10:32 PM
doodawg
May 24, 2009 06:45 AM
Quick444
Feb 19, 2009 09:58 AM
jamesmonty
Jul 18, 2003 11:11 PM
