Cold engine = Bad performance.
Old Aug 15, 2006 | 03:24 PM
Galizien's Avatar
Galizien
My 94 w/302 and fresh transmission has been having a problem where when I first start the truck and drive, I get sluggish power.
Then it seems like after about 30-60 seconds of taking it easy out of the neighborhood, the truck wakes up, like the engine temp goes more to normal and the truck drives 100% fine, no problems at all.
As far as I can tell fuel system seems good, fuel filter is new, gas is good, fuel pump seems to work fine. Its as if the the engine is encountering resistance. Not so sure though.
Could a bad thermostat cause these symptoms? acting like a blockage in the cooling system?
I have a slight exhaust leak near the Y pipe, and when it goes through the 1 minute of cold running lazyness, the exhaust leak gets alot louder. Could this be a clue?
Old Aug 15, 2006 | 03:26 PM
biggreentank's Avatar
biggreentank
Have you replaced/cleaned the idle air control valve?
Old Aug 15, 2006 | 06:39 PM
Galizien's Avatar
Galizien
I have not replaced it, but I have cleaned the hell out of it.
It still gives me fluctuating idle every once and a while, cold engine or hot engine..
Do you think this could be a probable cause of the poor cold engine performance?
Old Aug 15, 2006 | 06:56 PM
quicklook2's Avatar
quicklook2
sometimes they can be cleaned and sometimes they need to be replaced.
Old Aug 15, 2006 | 10:12 PM
biggreentank
I'd say it would be. Try replacing it. If it doesn't fix it you probably needed a new one anyway.
jasonmartin206
Sep 9, 2013 04:35 PM
Square Grouper
Dec 16, 2011 02:18 PM
chrisjrosenbohm
Mar 15, 2010 09:10 PM
Peter94
1983 - 2012 Ranger & B-Series
15
Aug 9, 2005 02:06 PM
