Dynamic compression ratio
Old Aug 14, 2006 | 10:42 AM
WarWagon's Avatar
WarWagon
What would be the maximum DCR for a wedge head with tight squish in a towing situation? I was figuring around 7.5, but I've never had any direction on this.
Old Aug 18, 2006 | 06:48 PM
rusty70f100's Avatar
rusty70f100
I'd say 8.5:1 for regular unleaded.
Old Sep 7, 2006 | 10:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check out the new DCR calculator on the edyno site from our member danlee:
www.edyno.com
Old Nov 25, 2006 | 11:49 AM
WarWagon's Avatar
WarWagon
Well......it's together and running on 87, no problem.....8.9 mechanical, 7.6 DCR, .036 squish.
Old Dec 30, 2006 | 09:24 PM
bigsnag's Avatar
bigsnag
8.5 DCR would be WAY high. 8.9 static is fine. Maybe could have squeezed it just a touch more, but why? You wouldn't gain that much and would risk needing to run premium. Sounds like a nice rig, War.
Old Dec 31, 2006 | 06:20 PM
rusty70f100
I was running 8.5DCR in my 390 for quite a while. All it took was getting the timing right.
Old Jan 26, 2007 | 12:25 AM
roger dowty's Avatar
roger dowty
the FE's have incredible quench design from what I've heard.. Wonder why that is as compared to other designs?
Anyway I'm getting ready to run 9.5 static with a 212/218 cam in a 400- aussie-iron-quench heads. I ended up with a 8.3 or so dynamic which will need 95-97 octane compared to conventional wisdom- running propane so I'm ok but I will try it with 92 at some point and see how it does with tmeyer's pistons that are designed for the quench heads- wish the heads were alloy....
Old Jan 30, 2007 | 01:27 PM
mustang81's Avatar
mustang81
i'm building a cheap 400 with aussie head with silvolite cast piston and 212/219 cam.My dynamic cr is 7.96 and static cr 9.25. I think i'm in a safe range.Most of engine make there best power with dcr between 7.5 and 8.5 on 91 or better octane.
Old Jan 31, 2007 | 01:05 AM
roger dowty
sounds like my kind of low-end torque monster build!
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
