Base Ignition Timing, 4.9
Old Aug 12, 2006 | 07:18 PM
mantta's Avatar
mantta
Does anyone out there know what the base ignition timing is on an 88 F-150 with the 4.9 and an AOD tranny? My vehicle emmisions decal has been missing since I have owned the truck. I am thinking that it is 10 degrees BTDC.
Thanks!
Old Aug 13, 2006 | 05:23 PM
mantta's Avatar
mantta
I pulled the spout plug today and put a timing light on it and the base timing was around TDC. I moved it up to around 11 Degrees BTDC and took it for a ride, wow, what a difference. Not pinging either.
Old Aug 13, 2006 | 05:51 PM
quicklook2's Avatar
quicklook2
10 degrees btdc with spout removed is the stock setting.
why was yours so far off? how long were you driving it like that?
Old Aug 13, 2006 | 05:53 PM
mantta's Avatar
mantta
I have had the truck for six years, I never have checked the timing on it. It only has 78,000 original miles on it right now.
Old Aug 13, 2006 | 07:21 PM
optikal illushun's Avatar
optikal illushun
try moving it to 12 then 13 and maybe 14...see which is better for u.
but its 10* BTDC.
Old Aug 13, 2006 | 08:51 PM
quicklook2's Avatar
quicklook2
than all that time it was running ok?
does not seem like it should have.
Old Aug 14, 2006 | 09:45 AM
mantta's Avatar
mantta
It started fine and ran olay but, it did not seem to have the power it should. It has it now! I also checked the fuel pressure and it is 46 psi.
Old Aug 14, 2006 | 10:08 AM
quicklook2's Avatar
quicklook2
just goes to show you that no matter how many miles or how old you need to go through the entire vehicle when you buy it.
i find it hard to believe you drove it like that for six years before realizing it lacked power.
Old Aug 14, 2006 | 10:12 AM
mantta's Avatar
mantta
I have never had a 4.9 before. I made three 3000 mile trips with it and averaged around 19 MPG on the interstate. It just did not have the get up and go my old 390 had in my 71 F-100 but, I thought hack, it is a six.
bcrone821
17
Jun 10, 2015 01:55 AM
Iceland_Man
Jan 8, 2014 10:27 AM
fishforlife2007
Apr 7, 2009 08:32 AM
shotgun
16
Apr 10, 2002 08:31 PM
