front hitch?
Old Aug 12, 2006 | 06:59 AM
1buzzbait's Avatar
1buzzbait
front hitch?
i need to put a 2" receiver for a bike rack on the front of an 01 x, it bounces way to much on the back of my travel trailer damaging stuff anybody have any success?
Last edited by 1buzzbait; Aug 12, 2006 at 07:00 AM. Reason: left a bunch of important stuff out!!
Old Aug 12, 2006 | 07:26 AM
71DRAGON's Avatar
71DRAGON
http://www.leedengineering.com/index.html
Old Aug 13, 2006 | 12:03 AM
RACERX7775's Avatar
RACERX7775
Smile
what happens when you want to have one in the center. for a winch, thats not bad. only 350 tongue weight. but 9000# line pull. not bad. i would prefer 1 hitch with the receiver in the middle
Old Aug 13, 2006 | 01:51 PM
housedad's Avatar
housedad
Front hitches like you want are maufactured by almost all the hitch makers. Draw-tite, Reese, Hidden Hitch. They are rated at 9000 Lb pull, 500lb hitch weight. They are in the center, and come out in the skrt opening where the fog lights are. You must remove the fog lights to install the hitch. Check out each of the manufacturers. Check out hitchesonline.com
Putnam also makes a hich for the front. It supposedly does not require removal of the lights, but it comes out under the skirt, in a rather low position.
Another alternative is This company, https://bodiaknet.powweb.com/store/catalog/
They offer a center hitch that dooes not require removal of the fog lights, and it mounts onto the current tow hooks. 9000lb pull, 500 lb hitch weight.
Old Aug 13, 2006 | 02:31 PM
1buzzbait's Avatar
1buzzbait
thanks dad!!
Old Aug 14, 2006 | 10:25 AM
1buzzbait's Avatar
1buzzbait
has any one had any success with bodiak? it looks too easy!! 2 bolts!! sure would like some feedback on that before i shelled out almost $200.00
Old Aug 14, 2006 | 12:18 PM
05Lmtd's Avatar
05Lmtd
I couldn't get that link to work. The one below should work.
It looks like a slick deal. I wonder about tongue weight capacity?
If it is rated Class III it should withstand at least 500 lbs, right?
https://bodiaknet.secure.powweb.com/store/catalog/
abendx
Aug 12, 2002 01:53 PM
Drawsoncad420
Aug 10, 2002 05:07 PM
BeeerMan
1997 - 2003 F150
Aug 9, 2002 09:52 AM
canadianfordman
Jun 3, 2002 03:37 PM
bsprowl
Aug 3, 2001 04:56 AM
