raising front end
Old Aug 2, 2001 | 08:13 PM
bsprowl's Avatar
bsprowl
raising front end
Old Aug 2, 2001 | 10:14 PM
taurus's Avatar
taurus
raising front end
hey guys, I want to raise the front of my 90 F150 2wd to match the height of the rear. What is the best way to do this? I was thinking of using the front springs out of an f250. Would they work? The reason I am doing this is for a little more ground clearance and to have more clearance for my new 31x10.5 tires that are going to be put on next week.
Thanks
Old Aug 2, 2001 | 10:47 PM
mrgoodwrench's Avatar
mrgoodwrench
raising front end
Using taller springs will work, but it will cause excessive negative camber this will cause tire wear and handling problems . If you very serious about lifting your front end, it can be done but it takes alot of modification, and fabrication. If cost is'nt an issue, I believe Fabtech motorsports makes a custom I-beam kit, but as I remember they were quite expensive.
John
GM writes my paycheck, But all I drive IS FORDS
Old Aug 3, 2001 | 04:54 AM
Fordtruxrok's Avatar
Fordtruxrok
raising front end
I can't remember who makes it but there is a 3" kit out there that uses a bracket between the I-beams and the frame, so you don't need to replace the I beams, and it comes with springs also. Cost was between $200 and $250 or something like that, but this was about 6 months ago.
John
Old Aug 3, 2001 | 04:56 AM
Fordtruxrok
raising front end
Oh by the way MrGoodwrnech, isn't negative camber when the tires lean in?? When you raise I-beams the tops of the tires lean out. Wouldn't that be positive camber??
John
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
