leveling kit question
Old Aug 11, 2006 | 05:03 PM
nikates's Avatar
nikates
what kind are all of you running.
i have a super lift spring installed and it sounds like a d**n mouse in the front of my truck. does anyone else have this problem.
and do any of you guys have the drop shackle kit in if so does it work. (does it lift the front and keep the same ride)
thanks nick
Old Aug 11, 2006 | 05:21 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I hear that same mouse from time to time.
Old Aug 11, 2006 | 05:35 PM
nikates's Avatar
nikates
my mouse is at every little bump in the road very anoying
Old Aug 11, 2006 | 06:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i have the Rough Country replacement spring pack leveling kit and it's perfectly quiet. the noise you are getting is because there is no teflon scrape pad at the ends of the add-a-leaf spring, and the spring just rubs against the stock leaves and makes the squeak. i rode in JTharvey's truck and i noticed that EXTREMELY annoying squeak.
my leveling kit added about 2-2.5" to the front, and it made it ride great. there is 5 thinner leaves and not 3 thick leaves like the stock spring "pack" with a add-a-leaf. it made my truck level. then i decided i wanted a 4.5" lift, and since my truck was already i didnt want to change out my perfectly-fine, almost new spring packs. so, i bought a Donahoe 4.5" spring hanger kit. added 4.5" front and 4" rear in the form of blocks. yes it's 7.5" of block but im going for new Deaver spring packs that eliminate the blocks alltogether after i get some new wheels and tires. it's in my webshots gallery. damn, their stuff is MASSIVE. it was really expensive for what i got, but it was the best and gives me peace of mind. it retains the same spring ride that i had when it was just leveled. but the overall ride is alot better and firmer (not harder) with the new Bilstein 5100 shocks which are just amazing, and they look good.
Old Aug 11, 2006 | 07:06 PM
cvdenson's Avatar
cvdenson
While we're on the subject of leveling kits, I've not been able to find any for 2x4 applications, do they make them?
Chris
Early '99 F350
Old Aug 11, 2006 | 08:45 PM
Turbo_Whistler's Avatar
Turbo_Whistler
I have the DR 3" hanger and shackle kit. DR makes beefy well built stuff. Works great and allows me to use my stock leaf springs. With my bilstein shocks, I have a better ride that feels a tad better than stock.
Old Aug 11, 2006 | 09:25 PM
nikates's Avatar
nikates
my mouse is in the front hanger on both sides
Old Aug 11, 2006 | 10:09 PM
Turbo_Whistler
How is the hanger squeaking?
Old Aug 11, 2006 | 10:15 PM
PowerstrokeJunkie
do you have an add-a-leaf in there causing the "hanger squeek"? if so, im betting that it's the problem, metal to metal contact. if it is infact the hanger, im guessing bushing on the front bolt is worn or needs some lube? never heard of that though.
nikates's Avatar
nikates
sorry its not actually a hanger but the soild mount at the front of the spring on the frame i can attually pust down on the front of the truck and it squeaks.
i didn't know if it was because of the new angle the spring is at or what could be causing it ive put about five of these kits on different trucks and never had it sound like this before.
Old Aug 11, 2006 | 10:18 PM
nikates's Avatar
nikates
double post
Old Aug 11, 2006 | 10:22 PM
PowerstrokeJunkie
well, actually the thing that the front spring mount connects to is technically a "hanger" i have two stock ones sitting on my shelf. here is donahoe's version of a "hanger"
are you sure it is that joint where it is squeaking? remove the bolt and put some grease in there. it's basically like disconnecting the spring so its not a extremely easy task.
Old Aug 11, 2006 | 10:32 PM
nikates's Avatar
nikates
i wasn't talking to you about calling it a hanger i corrected myself
Old Aug 12, 2006 | 03:44 PM
HP junkie's Avatar
HP junkie
I have Tuff Country 2.5" leveling kit and love it! A good level with a good ride. I am happy to say no squeaks or clunks from my front end. Now I just need to fit wheels and tires on my rig!
