Sender location ???
Old Aug 11, 2006 | 04:54 PM
jetdoc's Avatar
jetdoc
Sender location ???
Where is the best place to install the water temperature sender? I'm going to install a overhead triple gauge mount this weekend. I went with Autometer ultra lites oil pressure water temp and fuel pressure. Not really thrilled that the gauge mount is held with velcro but oh well. Thanks in advance
Duncan
Old Aug 11, 2006 | 05:28 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you haven't added a coolant filter the side port on the water pump is a perfect place.
Old Aug 11, 2006 | 05:44 PM
jetdoc's Avatar
jetdoc
I'm changing my water pump on Sunday and installing coolant filter at that time as recommended. Any place else?
Old Aug 12, 2006 | 07:53 AM
tjbeggs's Avatar
tjbeggs
put a "t" in that port for both
Old Aug 13, 2006 | 05:33 AM
jetdoc's Avatar
jetdoc
OK Thanks...I'll look into that.
Duncan
Old Aug 13, 2006 | 10:07 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
on the coolant filter head, there is two unused ports that you can tap into. one that sticks upward that i would not use do to hood clearances, but the one on the side in the picture below is where i will tap mine into eventually. plus i am almost positive it's the same size as the water pump port so the sender should slide right in.
Old Aug 13, 2006 | 12:11 PM
jetdoc's Avatar
jetdoc
Thanks Kris...what I wanted!!
Duncan
Old Aug 13, 2006 | 02:18 PM
Uzumati's Avatar
Uzumati
kris where does the line from the T next to the degass bottle go? I have not seen that setup on any of the kits.
Old Aug 13, 2006 | 03:28 PM
PowerstrokeJunkie
that is the stock line running into the degas. i suppose i Tee-d mine in a little different way so that it looks like that.
here is how it was when it was filter-less. http://img.photobucket.com/albums/v3...t/DSCF2577.jpg
