Sponsored by: Kumho
What could go wrong?
Old Aug 10, 2006 | 10:22 PM
ddmcsc's Avatar
ddmcsc
Question What could go wrong?
Hi, I was looking 4 answers and surfed my way into here. Easy signup......yes indeed.. I hav middle+ level abilities @ R&R. Mostly OJT. First Ford. ~1971 a 55 Yellow 292" w/ Dodge buckets & very clean. 14 yrs L8er, sold the PU and kept the wife. 21 yrs more and still drivin the same wife. Cherry 86 4X4 F250 w/60,000mi 4 $1,500... I can learn 2 love Fords again. It's my first post in here and it says i won't get bit. Hey, what could go wrong? Thanks 4 lettin me in and i hope it will work out 4 us all. A little help pointin me towards the 'my problem is' section...and I'll b around to check the site out. Thx again, ddmcsc
Old Aug 10, 2006 | 10:24 PM
ddmcsc's Avatar
ddmcsc
ny first answer comes from myself....... "what if i don't get any responses?"
Old Aug 10, 2006 | 10:36 PM
ddmcsc's Avatar
ddmcsc
answer :Just ask the Q ....
my 86 4X4 F250. I hav driven it fror a couple weeks. yesterday on a short trip, the dash abs and brake lights come on. i notice a power drag and smell hot brake shoe. it finally locks up the rear wheels. L8er on after it cooled down, it was able to roll again. Do these symptoms point @ any known brake problem?
Old Aug 11, 2006 | 05:30 PM
andym's Avatar
andym
You have ABS on a 1986 truck? I thought that wasn't availabe until 1987.
If you have ABS (I'll assume you do ) then it sounds like your ABS valve has gummed up internally and isn't letting the rear shoes retract like they should. I've seen it happen on Ford trucks before.
Old Aug 12, 2006 | 09:31 AM
ddmcsc's Avatar
ddmcsc
Thanks Andym, I hav never heard of an abs causing problems B4. I had bled the rear throughly and saw no sign of 'gumming' @ that time. How can I check 4 gumming or is it R&R time. You r correct it is an '87', it was first sold in '86'.
Old Aug 12, 2006 | 12:46 PM
andym's Avatar
andym
What happens is that it doesn't let the fluid retract the shoes after you press the brakes. The shoes are still pressing against the drum, and it will give you those symptoms. After a while, the springs in the drum are able to put enough pressure on the fluid so that it backs off enough to allow the wheel to turn. Then you hit the brakes and try it all over again.
What I would do in this case is get a piece of brake line and bypass the ABS valve. They're expensive to replace and the rear ABS system sucks anyway.
Old Aug 12, 2006 | 03:49 PM
ddmcsc's Avatar
ddmcsc
Thanks again Andym, Yer my kind of wrench. if it don't work, eliminate it. I'll do that right now and give the results. I Really appreciate yer takin the time 4 me. The truck is still a cream puff @ 20yrs. Thx ddmcsc
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
dlynes
Oct 23, 2017 04:38 PM
mmortensen
1997 - 2003 F150
Feb 3, 2013 03:17 PM
Bob97F350
19
Apr 13, 2009 05:10 AM
1FineBroncoBabe
79
Mar 4, 2006 03:09 PM
