Loose shifter
Old Jul 18, 2002 | 09:01 AM
fsmartin's Avatar
fsmartin
Loose shifter
I replaced the shifter linkage bushings and the shifter is still VERY loose. What else could it be? I have heard of some things in the steering shaft that wear out that are a complete pain to change...could these things be the culprit? What are they?
Old Jul 18, 2002 | 09:27 AM
airharley's Avatar
airharley
Loose shifter
Just out of curiousity how long ago was your last trans rebuild? You could try to disconnect the linkage from the trans and feel for play at the trans input levers. You could have worn shift forks. But this is a curiousity thing so I could be way off.
Old Jul 18, 2002 | 02:14 PM
fsmartin's Avatar
fsmartin
Loose shifter
Tranny was rebuilt about 30k miles ago. I checked the transmission linkage and it feels pretty tight. I believe it is in the column somewhere.
Old Jul 18, 2002 | 03:04 PM
44dwarf's Avatar
44dwarf
Loose shifter
There are several places the column wears out.
1) On the shifter tube at the top where the shifter lever fits in the little ball socket wears down. The factory doubled plated this area but hell it's 30+ years old. You can if skilled braze it up and redrill the hole but you need to make sure it's just right. Not a fun job.
2) At the bottom of the tube theres little cutouts the move the column forks these nubs round off over time.
Look back a few months I posted a link to a blown up pict of a bronco's column which is the same design but not sure the same over all fit.
44
Old Jul 18, 2002 | 03:07 PM
oleblue70's Avatar
oleblue70
Loose shifter
David Watson707
22
Jul 10, 2018 09:45 PM
blueoval65
Oct 10, 2014 08:41 AM
webstar61
Oct 31, 2012 08:15 PM
mike_rockwell
Jan 15, 2010 05:52 PM
Faderup
Apr 20, 2002 06:37 PM
