A/C Vacume prob?
Old Aug 9, 2006 | 09:43 AM
Fully_Loaded's Avatar
Fully_Loaded
A/C Vacume prob?
If I put my A/C switch on max in my 91 it will switch to defrost above about 1500rpm and stay there until I return to idle. I also do not believe that when I switch from normal to max there is any change. This is a vacume prob right? I just need to know where to start. Thanks
Old Aug 9, 2006 | 09:56 AM
hhott71's Avatar
hhott71
its a Vacuum problem.
Old Aug 9, 2006 | 10:08 AM
Fully_Loaded
Any ideas where to start? Or which lines control this?
Old Aug 9, 2006 | 06:58 PM
PCWest13's Avatar
PCWest13
Yeah, im having the same problem actually. If anyone could give any advice on this it would be great.
Old Aug 9, 2006 | 10:20 PM
Steina's Avatar
Steina
CO River Rat
If your '91 has a vacuum-controlled valve in the engine compartment that shuts off coolant flow to the heater in MAX A/C, see if the vacuum line to it is disconnected or has a hole in it.
Steve
Rus01
Oct 20, 2016 11:01 PM
04superduty6.0
Jul 23, 2016 11:43 AM
tigwelder
25
Jul 18, 2009 10:26 PM
myjaycopuller
Aug 3, 2004 06:22 AM
Yelrisheam
Sep 27, 2003 09:58 PM
