upper or lower separator plate gasket
Old Aug 7, 2006 | 02:36 AM
ajm859830's Avatar
ajm859830
I ordered a transgo shift kit for my f150 w/ 4.2l + 4R70W last week. I finally got the kit today and one of the separator plate gaskets is torn. Instead of waiting longer and possibly spending more money than the gasket its self to send the kit back im just going to go to ford and pick up a new one but heres the problem. I have NO CLUE weather it is the upper or lower one so thats why im posting. Can someone help me determine which one it is by a few "features"/holes it has. Also it is the transtec one that comes in the kit with the light blue stripe. A pic is below.
Old Aug 7, 2006 | 09:45 AM
stuart1's Avatar
stuart1
You are in luck.
I am doing one at the present time and will have a gander for you.
Hang in there.
Old Aug 7, 2006 | 09:51 AM
l-m tech's Avatar
l-m tech
its the valve body to seperator plat gasket.the other gasket is the one that fits between the valve body to case.
Old Aug 7, 2006 | 12:04 PM
ajm859830's Avatar
ajm859830
I went to ford and picked up the gasket. For the most part everything matches up fine. The transtec one that game with the shift kit has 4 holes that the one from ford does not though. Any ideas?
Old Aug 7, 2006 | 12:48 PM
ajm859830's Avatar
ajm859830
Heres another pic. The red dots are roughly where the kit gasket has holes and the factory gasket does not.
Old Aug 7, 2006 | 01:07 PM
l-m tech's Avatar
l-m tech
the best thing to do is check the gasket against the seperator plate when you do the kit if there arnt any holes you will probably be ok
Old Aug 7, 2006 | 01:18 PM
ajm859830's Avatar
ajm859830
Sounds good. Considering that gasket is for the 4R70W and I also bought the one with the 3 big holes (didnt need it) im going to take it back and pick up the one similar to above for the AODE. Correct me if im wrong but even though its called aode/4r70w they are two separate transmissions right?
Old Aug 7, 2006 | 01:37 PM
stuart1's Avatar
stuart1
sheesh
I should have known from the picture.
The gasket you show is between the separator plate and body.
The other gasket has large cut outs for the stiffener plates.
bigredtruck
Nov 29, 2022 01:30 PM
86F150302
26
Dec 30, 2016 08:25 PM
rlacan71
13
Aug 19, 2015 03:07 PM
henritrinelli
1978 - 1996 Big Bronco
Jun 30, 2012 09:04 PM
locked up
Jul 7, 2011 07:16 PM
