As far as sucking it thru a vacuum line, I feel like it cleans the carbon out of the semi-upper and lower intake, as well as the injectors. Just running it through the fuel tank will only clean the lines, filter, injectors, etc. It won't reach the intake.
Nightrain
but at the same time, many on this site will argue that sucking through the booster line will NOT touch the injectors.
I bought some of this stuff hoping my brother would be able to help me locate the break booster line but we don't know for sure which one it is. Can anyone help me locate the break booster line on a 95 351?
behind the master cylinder there is a large round black tank (master cylnd is mounted to it) in the 10:00 position you will see a large hose about 1/2 " diameter thats the hose take off the conector that goes in the booster as it might have a check valve on it
I've started to notice Sea Foam here in the Southern Wal-Mart stores recently. I don't know about the Northern Wal-Mart's, or whatever department stores ya'll have up there.
Any part stores in your area should carry it, though.
