Dylectric grease
Old Aug 6, 2006 | 03:33 PM
CrazySpyder69's Avatar
CrazySpyder69
Dylectric grease
Well im about to go change the plugs on my 2001 2.5l and I wanted to know if dylectric (sp?) grease is really needed. I dont have any and I dont have the money to go buy some. Also where does it go? Does it go where the wire connects to the plug?
My dad said he has never used it and has never had any problems. Thats why im asking.
Old Aug 6, 2006 | 04:07 PM
Bob Ayers's Avatar
Bob Ayers
Dielectric grease acts as a moisture barrier in the plug wire boots (plug and coil pack), and also keeps the boots from sticking to the plugs when they are changed the next time. If you are going to keep the truck long enough to change the plugs again, dielectric grease is recommended.
Old Aug 6, 2006 | 04:11 PM
Greywolf's Avatar
Greywolf
Buddy - I wouldn't worry much about it.
The best way to protect your plug wire boots (and make them easy to get on and off) is to put a light coat of plain old vaseline on the plug before you slide the plug boot over it.
The whole idea is to provide a barrier against water intrusion (and thus: CORROSION) without insulating the plug from the wire. Petroleum jelly (vaseline) is good for that, and I always keep a tub of it around for batteries anyway. It only costs a buck and a half at the most.
*NOTE: Mark that tub of vaseline "GARAGE ONLY" with a black marker.
Old Aug 6, 2006 | 04:54 PM
CrazySpyder69
What about WD-40? Would that work too?
Reason im asking is im on a VERRY tight budget, and I have WD-40
Old Aug 6, 2006 | 05:01 PM
Rockledge's Avatar
Rockledge
You can find small "one shot" packets of dielectric grease up front at the counter of most parts stores for like half a buck.
Old Aug 6, 2006 | 05:33 PM
CrazySpyder69
Ok sounds good, I think I can handle that.
Thx for the help guys.
Old Aug 6, 2006 | 08:00 PM
Greywolf's Avatar
Greywolf
You do what you want. But I always use vaseline for that stuff, & I been doing electronic stuff for more than twenty years.
Old Aug 6, 2006 | 08:07 PM
jimdandy's Avatar
jimdandy
Smile
WD-40 evaporates and is not good for long term lubrication, temporary only.
Whatever grease you use, use sparingly. The grease will seal the inside of the boot, and if you have to take the boot back off for some reason, yoiu might have some difficulty. BTDTGTCCTSBC. jd
Old Aug 8, 2006 | 09:23 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave
Looking back, the first time I saw he stuff was for use when changing ignition modules.
It was applied to the where the TFI module would contact the distributor and it worked as an electrical isolator.
Ever notice that brownish grease that was once used around light bulbs used for taillight and parking light sockets?
Old Aug 9, 2006 | 05:17 AM
Bob Ayers's Avatar
Bob Ayers
At one time it was used on power device heatsinks for better heat transfer.
Old Aug 9, 2006 | 07:14 AM
Alan D.'s Avatar
Alan D.
I had that happen once. It made it a real pain to get off because no air got between the boot and the sparkplug. it was like pulling a huge sucton cuo off the window.
Vaseline is a good enough insulator for the job your doing. i thing you'll need about 6,000 volts to jump across it.
Old Aug 9, 2006 | 09:29 AM
Rockledge's Avatar
Rockledge
That's interesting. In my experience, the grease actually helps keep the boot from sticking.
FWIW, the dielectric grease that Ford recommends for lubing/sealing the boots and other electrical connectors is also the same stuff Ford recommends for lubricating the slide pins on disc brakes.
Old Aug 9, 2006 | 11:17 AM
Alan D.'s Avatar
Alan D.
it wasnt that the boot was glued on, it just had too much grease and was acting like a chinnees finge trap on the boot. once air got in ther, it was fine
illnastyimpreza
1997 - 2003 F150
Nov 22, 2012 12:39 AM
acf6
Jul 19, 2011 09:01 PM
renoduckman
Oil & Lubrication
Jun 6, 2008 07:09 AM
vze2sgxa
Nov 29, 2007 09:24 AM
wyazel1
43
Jul 7, 2007 12:37 PM
