OEM radio
Old Aug 4, 2006 | 11:06 PM
skeneguy's Avatar
skeneguy
OEM radio
Hey,
Trying to keep my truck all original so I bought a 80-86 OEM am/fm radio on ebay, my truck is an 82 XLS and I think the radio came from an 86. Looks like it fits...it's close but the display part that fits through the bezel between the ***** is just about a 1/16th too big. I don't mine keeping the radio for parts since they're hard to come by, but is anyone familiar with the bezel types/years......I'm a bit gun-shy about getting another one since this was surprisingly so close, but not quite!
Cheers
Old Aug 4, 2006 | 11:53 PM
Mil1ion's Avatar
Mil1ion
The year of production of that radio is on the label.
Look for a E0TF-19A198-AA type number
and the numbers belows it.
What did the radio cost you ?
Old Aug 5, 2006 | 12:07 AM
skeneguy's Avatar
skeneguy
Thanks for the help. The label is faded out and unreadable, I paid $10.
Old Aug 5, 2006 | 09:14 AM
Oaktree's Avatar
Oaktree
can you get the center bezel peice from a 86 and use it?
Old Aug 5, 2006 | 09:26 AM
jinserra's Avatar
jinserra
I changed the original dial radio in my 83 explorer with a am/fm cassette out of an 86 f150 and just cut the bezel to fit the new face.
Old Aug 5, 2006 | 11:00 AM
skeneguy's Avatar
skeneguy
Yeah, I know I can make it it with a bit of cutting, but I don't want to be cutting or replacing the bezel, would defeat my object of keeping it original since it has an XLS logo...but interesting jinserra you found the same problem with an 86 deck, which I think is what I've got, I guess I should make sure I get an 82.
Thanks
Old Aug 5, 2006 | 02:22 PM
jinserra's Avatar
jinserra
I ran into my problem because I went from the old am/fm dial radio that would not keep a station, to a factory digital am/fm cassette.
Old Aug 5, 2006 | 02:23 PM
jinserra's Avatar
jinserra
I forgot to add this. I wantedto keep the same wood grain that the rest of the had so thats why I didnt take the 86 bezel
Old Aug 5, 2006 | 03:45 PM
Mil1ion's Avatar
Mil1ion
Note:
All user's have 60 minutes to go back into a post to make changes.
Just click the EDIT button rather than the Reply button
Can you make out anything on that label ?
and does it look like this one
Old Aug 5, 2006 | 04:10 PM
skeneguy's Avatar
skeneguy
No, don't have that label, there is a number ink stamped in the same location: 4A2602883
Old Aug 5, 2006 | 04:57 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Anything from 1980 to 1984, if it is a shaft mount would fit fine. No cutting of bezels required. You may have to modify the radio wiring plugs though, cause they changed around Circa 1982-1983.
The earlier car radios from the 1970's will fit as well. The radios from the 1973-1979 pickups will not fit!
The only real differences between the 1980 to 1984 radios with shaft mount, is internal workings, and the faceplates. They changed the faceplates, the thing that has cassette tape and the radio dial on it. in 1983. But the older faceplates 1980-1982 will fit right on the newer 1983 or 1984 radio.
The cassette deck in my truck is a:
E4AF-19A198-AA
There is a picture of it in my gallery.
I also have a E3AF-19A198-AA, for parts and it is identical except for some of the internal circutry.
Both of these radio's fit fine without any cutting of anything.
I also replaced the speaker harness in the doors and to the radio with a harness out of a 1994 F-150, so I could use the newer E9AF-18808-AA premium speakers. You could modify the plugs for the newer speakers, but I like my wires without splices so, I just swapped harnesses. Fit like a champ.
I also lucked out and found a pair of Factory speaker baffles in the same 1994 F-150. The baffles take the hollowness sound caused by the doors out of the speakers and sound great when installed.
A Radio delete plate # D5UB-1104371-AA will also fit over the radio hole if you want to go that way.
Hope this helps...
Old Aug 5, 2006 | 06:16 PM
81-F-150-Explorer
Oh, and just to add some more information..
You need to use the Radio brackets:
E0TF-19A179-AB "Front Radio dash mount" for factory shaft mount radios
and
E3ZF-18888-BA, (For cassette decks) or the equivalent Part # for the rear stabalizer support mount that attaches to the back.
The Factory ***** are D7OA-18A932-AA, for the chrome ones.
Old Aug 5, 2006 | 06:29 PM
skeneguy's Avatar
skeneguy
OK, thanks for the info...I'll keep searching and use the 86 for internal spare parts
Old Aug 6, 2006 | 09:30 PM
Nathane's Avatar
Nathane
If your speakers are dead, or dying... I'm EXTREAMLY happy with my dual brand speakers. Paied $30 for the pair, they're 6.5" so I had to do some extreamly minor trimming (less then 1/8" all the way around... Can JB weld it to origional specs if you want)
The cutout diamiter for theese speakers is about 5 1/2" mabey 5 5/8"
If you'd amp them, I'm sure they'd sound like crap, but since they have a high sensitivity, they sound great off of low power.
~Nate
FrankGRUN
Sep 21, 2017 12:57 PM
F350moneypit
Apr 4, 2017 08:01 AM
85MOTORSPORTXLT
80
Jun 11, 2016 07:01 AM
Gary Lewis
62
Apr 5, 2016 09:55 PM
tbruz
Sep 11, 2015 01:39 PM
