Engine cutting out, no DTC's
Old Aug 4, 2006 | 03:24 PM
Mtn Folk's Avatar
Mtn Folk
2002 7.3 auto 102,000 miles.
It started yesturday, cut out for a split second 3 times but kept running. Then today I was pulling up to a stop sign and it stalled. It started right back up. I have a SCMT, so when I got home from work I ran the diagnostics. According to the SCMT there were no DTC's.
Any suggestions?
Old Aug 4, 2006 | 04:13 PM
Uzumati's Avatar
Uzumati
Sounds like CPS going south they do not always set a code
Old Aug 4, 2006 | 04:58 PM
ryaneverk2's Avatar
ryaneverk2
I agree, most likely the CPS.
Old Aug 4, 2006 | 05:44 PM
Mtn Folk's Avatar
Mtn Folk
That's what I guessed, but I thought it would throw a code. The + terminal on both batteries (both are the original batteries) had a good bit of corrosion as well, I cleaned them as well.
Old Aug 4, 2006 | 07:02 PM
cgl's Avatar
cgl
When it momentarily cuts out, pay close attention to the tach. Mine did something very similar to what you're describing (except the complete dying at a stop sign) and my RPM's never dropped. When I lost my CPS my tach dropped to 0. It may not be your CPS....
Old Aug 4, 2006 | 09:36 PM
Uzumati's Avatar
Uzumati
2002 model year and later tach is not effected bt cps
Old Aug 4, 2006 | 09:48 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Wow, really? That's news to me. I need to file that away. What makes them different?
Old Aug 4, 2006 | 10:55 PM
02F250GREY's Avatar
02F250GREY
My 02 had the same thing happen to it. the ecu on the truck has to detect multiple malfunctions on the same system in a drive cycle before it will set a code for a check engine light. Also when you turn the truck off it clears the code until it happens again in another drive cycle. check your wiring to the cps to make sure it's not a wire grounding out on a rubbed through spot then replace sensor.
Old Aug 5, 2006 | 03:50 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome 02F250GREY, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 5, 2006 | 04:12 PM
Uzumati's Avatar
Uzumati
Not really sure what they changed but in 2002 the Tach is not soley dependent on the cps.That is why the tach does not move during cranking. kinda like the spedo where it can be run off a wheel speed sensor in case of VSS failure
Old Aug 7, 2006 | 12:51 PM
Mtn Folk's Avatar
Mtn Folk
I cleaned the corrosion off the terminals and the truck has not had any problems since. Could this have been the problem?
Old Aug 7, 2006 | 01:05 PM
PSNut's Avatar
PSNut
Don't count on it,unless the corrosion was real bad. Did u pull off the terminals and clean to bare metal and treat with baking soda/warm water solution?
Nut
Uzumati's Avatar
Uzumati
While you are at it check the 42 pin connector over the driverside valve cover and on the backside of it where the wires come out near the cover check them for chaffing.
CPS and electrical probs can be intermittant and its hard to tell if they are fixed until you get a few miles on the repair
79CEEJAY
15
Apr 19, 2004 10:52 PM
eeglot
Computer Chips & Tuners
Apr 1, 2004 05:37 PM
Foneguy
Nov 11, 2003 10:53 AM
klmnla
Sep 16, 2003 12:00 PM
klmnla
Aug 31, 2003 09:41 PM
