Sponsored by: Auxito
Missing piece on Sway-Bar!
Old Aug 3, 2006 | 09:36 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I just noticed this earlier this week when I was underneth the truck washing it. On the passenger side....the sway bar is disconnected from the mount on the lower A-Arm! I dont know how long it's been like that...whether it just happened last weekend, or if it was like that when I bought it.
Now I gotta fix it...
Would the dealership have this piece (bolt/screw), or do I have to buy a whole assembly?
Old Aug 3, 2006 | 09:55 PM
steve(ill)'s Avatar
steve(ill)
you can buy a universal "kit " at Auto Zone for $20 to do both sides. you get two bolts, rubber grommets, and two short pipes for spacers. only takes 15 minutes per side, do it. sometimes they break or the bolt rot off.
Old Aug 4, 2006 | 02:24 PM
7700Rob's Avatar
7700Rob
I found the the same thing on mine about a month back. I did the formentioned $20 route. I couldn't bring myself to pay $35 per side from the dealer. Not for this particular job. It's a real easy job to do though. I put the ole boy up on ramps for some elbow room. Rob
Old Aug 5, 2006 | 09:13 AM
Beast12's Avatar
Beast12
My dad had the same thing on his 99 F-150 about a month ago. Usually I fix his stuff for him but that was a job even he could do.
Not hard at all.
-Matt
Old Aug 6, 2006 | 02:13 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thanks guys. I'll do it as soon as I can...
Old Aug 6, 2006 | 02:50 PM
78bigbronco's Avatar
78bigbronco
I broke the head off my driver side mount a couple years ago and got the kit from Napa to replace it. Then after cranking up the torsion bars I popped the other side. But since cranking the bars the ride has been much stiffer and when the sway bar mount broke it rode nicer so I went ahead and removed both sides. With the bars cranked and the sway bar unbolted from each side it seems to have less sway then with the bar mounted before the lift. Oh well, I am happy, and one less thing to worry about.
Old Aug 6, 2006 | 02:54 PM
Nightrain's Avatar
Nightrain
Me and a bud were talking about this same issue on his 1997 F-150 4x4 last night...
His is missing the rod on the driver's side. Now I know how to go about fixing it...
Thanks, fellers!
Nightrain
Old Aug 7, 2006 | 01:54 PM
GammaDriver's Avatar
GammaDriver
Are you guys talking about "end-links," or some rod I don't know about?
If you're going to replace 'em, and if you're going to keep the truck, get Energy Suspension's polyuertane-bushing end-links (SUmmit Racing is cheap and has all the sizes (usually)). The end links are sturdier, IMO, and the poly makes the truck handle better. Probably less than $35 for the kit.
But for 'rods,' I'm just not sure who sells 'em. Gonna look under the truck tonight to see if I can find 'em though.
Old Aug 7, 2006 | 04:18 PM
78bigbronco
Nightrain was the only one who used the term 'rod', and yes the rest of us are talking about the end-links, although that term escaped me earlier. And I have heard good things about Energy Suspension's polyuertane-bushed end-links, never checked to see if they were avaiable for my f150 though and since decided to just disconnect the end links all-together.
Old Aug 7, 2006 | 04:49 PM
GammaDriver
Ah... everyone seemed on the same page, so I wondered if I was missing something.
To be honest, for my '99 4x4 I ordered what I thought was the closest sized end-links (I don't recall the size now - if someone really needs it, I may be able to call up Summit), then trimmed down the two center spacers to the size that the truck had. I probably could have left them the original size if I would have disonnected both sides before installing new ones, and played around with jacking the truck up (or the sway bay down) a little.
Old Aug 7, 2006 | 05:31 PM
78bigbronco
BTW, I bought just the long bolt from Ford and it costs more than the entire kit (both sides-all peices) at napa. I thought I could re-use the other pieces but quickly found out that I could not remove the bolt from the plastic hourlglass-shaped peice. I tried soaking it with some pb blaster for a couple days to no avail. So I ended up at Napa for thier heavy duty kit (advance auto parts didnt have it). So unless your truck is much newer I would say just trying to replace the bolt isnt going to work.
Old Aug 7, 2006 | 06:44 PM
bigdaddyII's Avatar
bigdaddyII
I ordered Moog replacements for mine from www.rockauto.com. Pretty simple and straight forward job.
Old Aug 7, 2006 | 06:45 PM
GammaDriver
One really shouldn't try to re-use the other pieces - the original soft rubber bushings only get softer (and some partially wear away) with time. If the truck is in a rust-belt area, the 'washers' may not be strong enough to hold over the life of the truck anyway.
This, like the rear shock studs up near the frame, may very well be a good place for a hacksaw (or, skip that, I used a Sawzall - the end-link hardware is pretty tough steel - a cutting torch will work, too).
Old Aug 7, 2006 | 10:54 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thanks for the Poly-bushing tip GammaDriver!
As for you guys who run with a disconnected Sway-bar...will it cause excess tire wear in the long run? As in leaning too much in a corner, and causing the tire to wear.
The reason I ask, is that I just got new M/T's put on the truck, and I want them to last as long as I can. Plus...I take this truck off-road regularly, and would like the extra flex/travel
Snowmobile02067
Jan 5, 2013 09:36 AM
pumpdriver20
May 1, 2012 08:29 PM
wicat3
Jan 18, 2012 08:55 PM
LJForrist
Jan 15, 2011 12:52 PM
PsD007.3
Feb 16, 2009 05:28 PM
