Base Timing And Total [351-m
Old Aug 2, 2006 | 03:47 PM
bad79bronco's Avatar
bad79bronco
Can Anyone Inform Me On Base And Total Timing Specs For A 79 351 M . I Just Installed An Edelbrock Timing Set In The Advance Position And The Truck Now Pings Like Hell
Old Aug 2, 2006 | 09:36 PM
mark a.'s Avatar
mark a.
You need to put it back at zero.
Old Aug 3, 2006 | 12:02 AM
bad79bronco
why ? it's only 4 degree advance
Old Aug 3, 2006 | 12:36 AM
Socketman's Avatar
Socketman
its really 8 degrees as stock is 4 retard. your building too much cylinder pressure.i presume this is a stock cam?
Old Aug 3, 2006 | 09:26 AM
bad79bronco
It's all stock , do you really think 4 degree's is too much !
Old Aug 3, 2006 | 09:28 AM
bad79bronco
it runs perfect , but when I tow it ping's . I have my dought's about going to straight up
Old Aug 3, 2006 | 06:25 PM
packlet's Avatar
packlet
ping == too much advance somewhere. if it started after you bumped base cam timing by 8 degrees, then that's probably the reason. unless you also disabled your EGR while you were at it... Even with EGR, straight up is the way to go, or you'll have to retard somewhere else (eg: max vacuum advnace)...
Old Aug 3, 2006 | 11:52 PM
bad79bronco
I did away with the egr and I will have to check base timing . do you know what total timig should be ?
Old Aug 4, 2006 | 03:27 AM
packlet's Avatar
packlet
see post #6 in this thread:
https://www.ford-trucks.com/forums/s...d.php?t=506678
