truck will not start
Old Oct 23, 2006 | 11:33 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I know all about the 12hr shifts bro. Good luck.
Old Oct 25, 2006 | 12:48 PM
Reckless's Avatar
Reckless
I was experiencing similar problems recently and was thinking complicated.
2000 7.3L F-250 4x4....Yesterday i went out to troubleshoot etc. Symptoms were truck would crank but not fire up. Couple days before I used a jump box to the primary battery (twin batts) on the pax side and it fired up. Tried yesterday without jump box and again it just cranked but not fire. So once again w/ the jump box and voila! fired up. This told me had to be battery related. So before pulling to replace, or going after a CPS, I just simply took off the cables and cleaned both them, and the terminals. it subsequently started quick and strong no problem several times over. Problem fixed.
With that being said, I think the batts are probably the originals (bought used) and I will be looking to replace them sooner rather than later for GP going into the winter.
...still wrestling with an intermittant heater vent directional flow issue where it more often than not, defaults to the defroster. That's another post though.
Old Dec 20, 2006 | 07:07 PM
highboyman's Avatar
highboyman
Talking 99 psd
I Installed A Reman Hpop And It Started. But When It Sat Over An Hour It Would Crank For About 20-30 Sec Befor It Started Found A Bad Injector O-ring. Replaced O-rings And Know It Runs And Starts Fine.
Old Dec 20, 2006 | 07:32 PM
Kwikkordead's Avatar
Kwikkordead
Good news.
Was the o-ring simply torn?
Old Dec 20, 2006 | 07:43 PM
Reckless's Avatar
Reckless
Mine definitely turned out to be dying batts. Bought the big nice ones from Advance Auto (Titaniums) for like $78 a piece. Problem solved.
sand1
16
Jan 12, 2019 04:32 AM
brokeasajoke
Dec 6, 2013 09:27 PM
ldst
Apr 27, 2012 07:16 AM
wheelie31
23
Apr 5, 2011 10:05 PM
ksubigbuck
May 18, 2009 05:25 PM
