Mack
Lmc truck carrys those reasonable. I got lucky and bought some parts from a guy who changed over to a tilt column and had recently rebuilt his old 1. That dang shift collar could be worn out to. My column had half the top of it busted off and the last dodo that had worked on the truck put in a floor shifter. He also reistalled the arms backwards on the column when he slapped it back together. .....
I'll DITTO the worn shift collar! That is usually the first problem. The spring pin hole wears out and the slack adds inches to the shift throw. Check that first, and these are available in the after market, maybe here?
William in Atlanta
