Steering Wheel Play
Old Jul 31, 2006 | 08:16 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i did mine a 1/4 turn too, and i didnt notice a single difference. im not going to go tigher in fear of locking it up as i have heard. i will try a dual steering stabilizer setup after new wheels and tires.
Old Jul 31, 2006 | 08:30 PM
Uzumati's Avatar
Uzumati
As long as you dont go to much at once you should be OK strokin. I have seen a few that took a couple of full turns (1/4 turn at a time).
Old Aug 6, 2006 | 09:35 AM
roaky81's Avatar
roaky81
My search function is not working or else I'd find my write up for this. The original procedure calls for a small inch/pound torque (on the steering wheel nut) to set the right preload on the steering box allen screw. What I did was to jack the front wheels up and put them on stands. Then I loosened the allen screw's lock nut several turns and then I lightly seated the allen screw (to find where it bottoms out) and then back it off and lightly seated the screw again. Then I turned the steering wheel "lock to lock" to check for any rough spots or binding. If it's all smooth, then tighten down the lock nut while holding the allen screw. This will pull the allen screw away from bottom and should be good to go. It's been a year since I did it and all is good. It also made a world of difference in my steering!
Old Aug 11, 2006 | 04:53 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I just finished trying this.
I tightened the stud approximately 1/4 turn. Test drove around the neighborhood and while it does feel a little tighter it does still have side to side play.
Am afraid to try this again due to the fact that people have told me that going to far can be disastrous to the steering box.
Maybe it's time to go to the front end shop.
Old Aug 11, 2006 | 06:36 PM
Cuda_jim's Avatar
Cuda_jim
This is the procedure copied from the book.
Adjust total on center load to eliminate excessive lash between the sector and rack teeth as follows.
With the engine off, turn the steering wheel from full right stop to full left stop at least once.
Remove steering wheel hub cover.
Disconnect the steering gear sector shaft arm from the steering gear sector shaft using Pitman Arm Puller.
Attach a newton meter (pound-inch) torque wrench to the steering wheel hub nut and determine the torque required to rotate the power steering gear input shaft and control back and forth across the center position (± 90 degrees).
Reset the meshload only if the measured torque for total on-center load is less than 1.5 Nm (13 lb-in). If reset is required, loosen the adjuster lock nut and turn the sector shaft adjuster screw until the measured total on-center load torque is 2.0 Nm (18 lb-in). Hold the sector shaft screw in place and tighten the lock nut to 48-61 Nm (35-45 lb-ft).
Recheck torque readings and replace the steering gear sector shaft arm. Tighten the pitman arm-to-sector shaft nut 230-310 Nm (170-228 lb-ft).
Verify no binding condition in steering throughout full stop-to-stop travel.
Replace steering wheel hub cover.
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1</TD><TD>—</TD><TD>Outlet Port (Part of 3504)</TD></TR><TR vAlign=top><TD>2</TD><TD>—</TD><TD>Inlet Port (Part of 3504)</TD></TR><TR vAlign=top><TD>3</TD><TD>—</TD><TD>Identification Tag
(Part of 3504)</TD></TR><TR vAlign=top><TD>4</TD><TD>—</TD><TD>Sector Shaft Adjusting Screw (Part of 3540)</TD></TR><TR vAlign=top><TD>5</TD><TD>3580</TD><TD>Steering Gear Sector Shaft Housing Cover</TD></TR><TR vAlign=top><TD>6</TD><TD>—</TD><TD>Lock Nut (Part of 3540)</TD></TR><TR vAlign=top><TD>7</TD><TD>3575</TD><TD>Steering Gear Sector Shaft</TD></TR><TR vAlign=top><TD>8</TD><TD>—</TD><TD>Control Valve Housing
(Part of 3568)</TD></TR><TR vAlign=top><TD>9</TD><TD>3D517</TD><TD>Power Steering Gear Input Shaft and Control</TD></TR></TBODY></TABLE>
Old Aug 12, 2006 | 08:25 AM
Texas Outlaw
Not a liberal...
Thanks for posting that. We will try it again.
Old Aug 12, 2006 | 03:10 PM
KrenzyRyan's Avatar
KrenzyRyan
I recently had alot of play in mine as well. I actually had someone move the steering wheel back and forth while I was under the truck looking at the steering assembly.
Turned out where the pivot arm bolted to the power steering box (stearing gear sector shaft), the large nut that holded that in place was 1 turn loose. Tightened it back up and it re-loosened again a week later, So I took that bolt and lockwasher completely out, dried everything up and applied loctite, seems to be doing okay now but I still have play. Not as much as I use to though. I have a spare tie-rod end that I might be replacing soon. I might even try what markadeck posted.
I have a question though, for those of you guys that have a 4.5 lift or higher with bigger wheels and tires, when you are at a standstill, and you go to turn the steering wheel, does it seem like you have no power steering? I am debating whether my power steering is going out or not. Seems to be good when I am moving though. Power steering fluid is good. any advice appriciated...
Old Aug 12, 2006 | 09:20 PM
Texas Outlaw
Not a liberal...
I have a 4" lift and 33" tires and yeah, sitting dead in the driveway the steering is tight. Once we start rolling it's back to normel but with too much play.
Old Sep 1, 2006 | 09:43 AM
Texas Outlaw
Not a liberal...
We finally found the source of the play in the steering of our truck. Turns out the Pitman arm wasn't torqued to the proper spec when the truck was lifted and that was allowing the arm some free play which we were feeling in the wheel. Went ahead and removed the Pitman arm, ran the procedure that Cuda_jim posted and then replaced and torqued properly. It drove much better. Had it aligned yesterday and now it drives like new.
Thanks for all of the advice from everyone.
Old Sep 1, 2006 | 01:44 PM
PowerstrokeJunkie
did you have to remove the airbag to do this procedure?
Old Sep 2, 2006 | 06:11 PM
Texas Outlaw
Not a liberal...
Yes, not that big of a deal though.
Old Sep 2, 2006 | 11:55 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
I just went outside and tightened mine a little. Held the stud while loosening the lock nut. Then turned the stud about 1/4 turn. Then held the stud while retighting the lock nut. Took it out down the highway for 1/2 mile or so and came back.
Did seem to work for me.Steering does not seem as loose. Seems to have made it a little more sensitive and responsive.
Can't wait for a true test while running down a straight road on a windy day. Also steering did return to center very easily so I guess I did not overtighten the stud.
Cool........Very Cool..... Learned something else from this site.....Again!!!!!
Old Sep 4, 2006 | 10:00 AM
  #28
Muktown's Avatar
Muktown
i had the same problem as you on my 2000 psd. heres a link on how to adjust your steering box and tighten up the steering play
https://www.ford-trucks.com/forums/419941-steering-problems.html?highlight=steering+problems
Old Oct 11, 2006 | 05:38 PM
  #29
RAMPAGE_F350's Avatar
RAMPAGE_F350
Originally Posted by amiller93
On top of the steering box there is a 15mm (i believe) lock nut with a hex head inside it. Tighten this hex head up and relock the 15mm. this adjust the gear mesh clearence.
Tighten the heax head no more than about 1/4 turn at a time and test drive after adjusting. To tight and the wheel wont return to center. I'll see if I can get some pics in my gallery as soon as it stops raining.
It took three 1/4 turns and my wheel play is gone.
Old Nov 18, 2009 | 10:36 AM
  #30
kord's Avatar
kord
I was getting alot of side to side movement on the steering wheel. So bad it actually seized a couple of times. Took it in yesterday and was told that this is a fairly common problem with this truck ('97 F250 HD). They said that people pull on the steering to assist getting into the truck.
Fix, they told me, was to replace u-joints, bushings and bearings on the steering assembly. Estimated cost...$600.00! ($300 parts - $300 labor). The service manual shows the process to be pretty involved.
Don't pull yourself in the truck by the steering wheel!
texasjack
40
Jul 30, 2023 12:04 PM
Ed1934
Nov 26, 2016 04:55 AM
pat420swed
Jul 2, 2016 08:44 AM
drof46
Jan 21, 2006 10:11 PM
jb1390
41
Jan 19, 2006 06:47 PM
