Steering Wheel Play
Old Jul 29, 2006 | 09:07 PM
kstiner's Avatar
kstiner
Question Steering Wheel Play
I Have a F350 PSD with 97k miles and the Steering wheel has a lot of side to side play. I know that it will have some play do to the fact that it has 97k on it. Would like to know how to lessen the play, Changed out the steering shock, had the ball joints checked said that there ok. Any help would be nice thanks to all.
Old Jul 29, 2006 | 09:11 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
have you checked all of the ball joints on both ends of the drag link, and both ends of the tie rod? there may be some play in them, most likely needing to replace one end of the part. do you have any suspension modifications or larger tires?
i have lots of steering wheel play, if i lightly hold the steering wheel it will jerk out of my hands hitting small bumps or going around curves. it is a handful (pun intended ) to keep it within the white and yellow lines. im investing in a dual steering stabilizer system for when i get 35's.
Old Jul 29, 2006 | 09:59 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
There is a very easy to access adjustment on the steering gear box. Involves an allen wrench and some damn size metric box wrench. Just don't go too tight with it as it makes the wheel way too sensitive.
Old Jul 29, 2006 | 10:13 PM
empiretc's Avatar
empiretc
Markadeck, we need someone to post a pic of that
Old Jul 29, 2006 | 10:55 PM
PowerstrokeJunkie
yeah, i would like to know that as well!
Old Jul 30, 2006 | 08:29 AM
kstiner's Avatar
kstiner
I had every thing on the front looked at by local shop and they said every thing look great. I will try the adjustment today a post when done. no it is totally stock. thanks
Old Jul 30, 2006 | 08:40 AM
Markadeck's Avatar
Markadeck
The gear box is very easy to get to. It is accessed from under to hood. If you have a 4 X 4 you will probably need a little step stool. It is self explanatory. My camera is too high a resolution to post an attachment and the owners manuel is in North Carolina and I am still in Alaska. There is a way to turn the resolution down, but I don't remember how...So sorry about no photo from me.
Old Jul 30, 2006 | 12:05 PM
PowerstrokeJunkie
email the picture to me at my FTE username @hotmail.com (strokin_it7.3)
ill resize it and then post it up.
Old Jul 30, 2006 | 12:06 PM
Uzumati's Avatar
Uzumati
On top of the steering box there is a 15mm (i believe) lock nut with a hex head inside it. Tighten this hex head up and relock the 15mm. this adjust the gear mesh clearence.
Tighten the heax head no more than about 1/4 turn at a time and test drive after adjusting. To tight and the wheel wont return to center. I'll see if I can get some pics in my gallery as soon as it stops raining.
Old Jul 30, 2006 | 06:47 PM
Uzumati's Avatar
Uzumati
Sorry bout the bad pic the lens keeps fogging up its so humid here.
If you can see the black spot in the center it is a lock nut with a threaded hex bolt through it. Tightning the hex bolt narrows the gear mesh clearence "tightening" the stearing.
** TO TIGHT AND THE STEARING WHEEL WILL NOT RETURN TO CENTER **
Old Jul 30, 2006 | 07:31 PM
clux's Avatar
clux
Just to reiterate what amiller93 and Markadeck said, make sure you don't overtighten it, or you will hate yourself. And don't ask me how I know.
Old Jul 31, 2006 | 07:07 AM
jetdoc's Avatar
jetdoc
I believe that is called the sector shaft adjustment. Be very careful with that. As posted previously, that can jam up the steering box when you least expect it. Been there done that, luckily it wasn't on a public road.
Old Jul 31, 2006 | 04:58 PM
kstiner's Avatar
kstiner
Smile
That work like a dream just had to turn only 1/4 turn and it took care of my play in the wheel thanks to all .
Old Jul 31, 2006 | 05:05 PM
PowerstrokeJunkie
im thinking about doing it too but im leary of the consequences. should i just go 1/8 turn at a time?
kstiner did you just do a 1/4 turn and leave it at that or did you get there in increments?
Old Jul 31, 2006 | 05:23 PM
kstiner's Avatar
kstiner
I did a 1/4 turn and left it there I thought about going a littel more but was just to scared to so i left it there and drove it for the day and i like it where it is sorry if this did not help thanks
