33s with a leveling kit???
Old Jul 29, 2006 | 02:15 PM
jdhakert's Avatar
jdhakert
I want to put 33'' tires on my 2006 Lariat and I originally heard that a leveling kit would do the trick as far as clearance. Today, however, when I got my Line-X installed (amazing btw, get one if you don't have one), the lady said that the installer said that it would rub every time I try to turn and would make a loud noise and wear the tires and the wheel wells down to nothing. Suspension lifts are nice but muy $$$ and I am only a poor little freshman in college. Does anyone have a leveling kit set up with 33s and a heavy 5.4L engine? Does it rub? Any advice or input would be GREATLY appreciated. Thanks
Old Jul 29, 2006 | 05:51 PM
DASTUD's Avatar
DASTUD
It will rub some at a full turn, but not to the extreme that you were told. My buddy has this set up and the rubbing is not bad. Save your money and put the skyjacker 3" suspension lift ($525.00) then there will be no rubbing. That is what i have on mine and love it.
Old Jul 29, 2006 | 08:07 PM
MichaelChesson's Avatar
MichaelChesson
I have the daystar leveling kit with 285/70 r17 cooper discovery stt they do not rub look at my galley for pic.
Old Jul 30, 2006 | 09:37 PM
Cavtrooper06's Avatar
Cavtrooper06
For an inexpensive but damn good lift that you could install yourself click here.
Its the autospring lift, I have it and many others do as well. Took about 2 hours to install and afterwards you'll need a toe-in alignment.
With this lift you would easily clear your tires. Autospring also has a 2" version as well.
Old Jul 31, 2006 | 10:24 AM
damuddog's Avatar
damuddog
I have 33- 12.50's 2.5" leveling kit and no rubbing. I did by aftermarket wheels though. They adjusted the offset.
Old Jul 31, 2006 | 10:28 AM
is300wrx's Avatar
is300wrx
2.5" Autospring with 17" aftermarket tires wrapped in 33" BGFs. No rubbing at all. Even at full turns .
P.S. Do a search next time
Old Aug 3, 2006 | 06:32 PM
InboundFX4's Avatar
InboundFX4
33x12.50 on 20" custom rims with 2" level. Zero rubbing at full turn. Nice fit if you ask me.
Old Aug 3, 2006 | 07:16 PM
FordTruckGuySTX's Avatar
FordTruckGuySTX
My truck clears a 33 stock and with daystar i could run 35s on the stock wheels
Old Aug 4, 2006 | 08:28 AM
tank55's Avatar
tank55
I am wrong here or is it the width of the tire that causes the rubbing not the heigth of the tire. My 4 x 4 has plenty of room for a taller tire. I don't see where a taller tire would cause rubbing in a 275 to 295 width.
buckshot85
Offroad & 4x4
Mar 9, 2010 09:57 PM
rtazz17
Sep 25, 2009 01:25 PM
cdrmotorsports
Aug 20, 2009 07:52 PM
sonneborn3
Dec 31, 2008 10:12 PM
FX2
2004 - 2008 F150
Sep 21, 2004 09:41 PM
