Tranny
Old Jul 27, 2006 | 11:19 PM
smoky1978's Avatar
smoky1978
Tranny
i have a 98 ranger 4x4 3.slow with an auto this ony happens very often but concerns me when im cruising down the freeway about 65-70 and i hit the accelerator just enough to somewhat accell the best way i can desribe it is a farting noise anything i should be woried about or the cause of the problem thanks for your time
Old Jul 27, 2006 | 11:47 PM
RangerPilot's Avatar
RangerPilot
Is there a power loss or does it slip or anything? You could have your codes checked, just in case, but that's a new one to me lol.
Old Jul 28, 2006 | 02:47 AM
smoky1978's Avatar
smoky1978
It will make the fart noise and i can here threw the tail pipe and it will only accel only slighly it did it on my stock truck but hasnt done it since i have put 33s on my truck which has only been about 6 months but just thought about it againt today and thought i would ask i always check the forums atleast twice a day so if you need more info let me know thanks for the reponse
Old Jul 28, 2006 | 10:18 AM
RangerPilot
Not a tranny issue. Very interesting indeed. One of the oldtimers might have some insight on it, that's nothing I've heard of though.
Old Jul 28, 2006 | 10:41 AM
FTE Trigger's Avatar
FTE Trigger
Question Highly confused?
Originally Posted by smoky1978
It will make the noise and i can hear through the tail pipe and it will only accel only slightly it did it on my stock truck but hasn't done it since i have put 33s on my truck which has only been about 6 months but just thought about it again today and
edit...(kind of)
So you are telling us the .... noise is gone???
Do you want it back???
Old Jul 28, 2006 | 11:43 AM
RangerPilot
I think he means it used to have the noise, it doesn't anymore, and now he's just wondering what it was.
Old Jul 28, 2006 | 10:26 PM
bigdavesohc's Avatar
bigdavesohc
The engine is probably stressed under load. The engine is designed to cruise at 2500 rpm, so it doesn't have a whole lot of power at that low rpm. All the engine is doing is bogging down as it gets enough power. Perfectly normal.
Old Jul 28, 2006 | 11:24 PM
CrazySpyder69's Avatar
CrazySpyder69
Tell ur g/f in the passenger seat to stop eating beans.
Just a joke...hope you take it as one. lol
Old Jul 28, 2006 | 11:37 PM
FTE Trigger
Question
Superrr Daveee..
His post is worded in way that makes you think that the "questionable noise" dissappears after the change From stock Tires to the bigger tires...
that is... unless he mis-worded his original post...
Ford XLT 4x4
Sep 2, 2011 01:43 PM
fdude64
56
Feb 24, 2008 07:00 PM
CaptGuz
North Carolina Chapter
53
Jun 2, 2007 08:41 AM
rhetor
Jun 29, 2002 08:55 PM
69 F100 4x4
Jan 8, 2002 12:07 PM
