Class V hitch?
Old Jul 27, 2006 | 06:39 PM
cumminpwr11's Avatar
cumminpwr11
Class V hitch?
did any Ex's come with a class V hitch as factory equipment? My hitch says class V but its seems alot smaller than the one that I had 1 ton.
Chris
Old Jul 27, 2006 | 07:02 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Every Excursion that rolled off the line at KTP came standard with a class IV hitch. The only reason you would have a class V is if you:
I. Owned a Super Duty.
II. They made a mistake at the factory.
II. If you bought it used, the previous owner put on a class V hitch.
Other than that, I don't know.
Old Jul 27, 2006 | 07:05 PM
cumminpwr11
it looks tiny, on my dually it was massive. just has me worried that someone slapped a new sticker on it.
yeah I bought it used, so I am not sure. Looks like a trip to a hitch shop to find out for sure. thanks for the help
Chris
Old Aug 8, 2006 | 12:57 AM
scubudo's Avatar
scubudo
Mine is labeled as a V as well. It is original. I have read in the past that it is not really a V...but don't recall why or how they got away with labeling it as one.
Old Aug 8, 2006 | 06:37 AM
Leader's Avatar
Leader
Just what determines the "class" of a hitch? I know someone is going to say the weight it can carry but who sets this standard? Is there any LEGAL definition? People get so wrapped up in manufactures recommended ratings but these don't have any relationship to the law in most cases. Is there any LAW against going over that rating? Has anyone ever gotten a ticket for doing so?
Old Aug 8, 2006 | 07:36 PM
BigEyedFish_69's Avatar
BigEyedFish_69
mine say class V as well and it appears to be stock
Old Aug 9, 2006 | 12:04 PM
5-Ryersons's Avatar
5-Ryersons
My hitch is labeled V-5 which can be misleading
A smaller label lists the max hitch capacity as 12,500 pounds with weight distribution which technically makes it a Class V hitch.
According to the UHaul website, V-5 is simply a minimum testing/rating system of trailer hitches established by the Trailer Hitch Manufacturers Association.
Old Aug 9, 2006 | 06:49 PM
Toreador_Diesel
This is proving to be a little more interesting than I thought. If you all (with the class V hitches) would post pics either in your gallery or via link of your hitches; we could probably sort this out a little better.
Old Aug 9, 2006 | 07:26 PM
CAFordDude's Avatar
CAFordDude
Ok Don't know if this helps But I have an 06 F350 PSD SRW. I posted pics of my factory hitch in my gallery. One with a ruler to get dimension size and one of the label.
Old Aug 10, 2006 | 10:22 AM
dmp437's Avatar
dmp437
Class 5
Mine's a Class 5 but's it's an aftermarket Reese Titan with a 2 1/2" receiver that's rated 17k pounds, weight distributing. In the barn I've got my '99 factory hitch that was rated 10k and my '03 hitch that was rated 12.5k and they're exactly the same.
Old Aug 10, 2006 | 02:34 PM
aklim's Avatar
aklim
I thought the stock receiever is 2 in? How did that work out? I looked at the Reese titan and couldn't see an application for the Excursion??
Old Aug 10, 2006 | 02:52 PM
osubob's Avatar
osubob
Nobody makes a replacement hitch for the Excursion. The reason is that the hitch on our X's are considered a "blocker beam" and part of the safety system. Nobody wants to take the liability of replacing a safety component. If I remember correctly, the hicth is rivited on, not bolted...
Old Aug 10, 2006 | 03:29 PM
cumminpwr11
alkim
is your titan on your X? whats the part number?
Chris
Old Aug 10, 2006 | 03:37 PM
aklim's Avatar
aklim
I don't have the titan. It is the other guy that does. DMP437
Old Aug 10, 2006 | 06:40 PM
housedad's Avatar
housedad
Mine is definately bolted on. For sure. 2005 v10 xlt
