It seems that since the max tow rating was upped to 11K for the 2002-2005 MY, Ford had to accomodate that rating by upgrading the hitch to a Class V; as opposed to the Class IV that came on the 2000-2001 MY X with a rating of 10K. Mystery solved.
So, does that mean a 2001 can have the class V reciever installed? I don't see a reason why not if it comes from the manufacturer.
To be perfectly honest, me either.
They probably strengthened the frame to accomodate the 11K rating in addition to the class V hitch. However, the X was probably capable of towing 11K all along. It's just that Ford was keeping it as a secret weapon in case the competition jumped out with something better; which Chevy did when they announced that the 3/4 ton 'burb was capable of towing 12K. So in order to close that gap, Ford announced that the X could now safely tow 11K for the 2002-2005 MYs. You COULD mount the class V on your X, but I think it's at your own risk. If you decide to, I'd get a bigger and better tranny cooler as that's one of the things they probably upgraded to get the rating to 11K.
Anyone know what they did to strengthen the chasis? After all, I thought the 6.0 Cooler came in the 6.0 motor not the 7.3. If the hitch itself is the same, why go thru all the hassle to get the different sticker??
Remember, even though the hitch sticker may say it has a Weight distributing max tow capacity of 12500lbs, and 1250 toungue weight, the published maximum allowable weight limits for hitch as installed on the Excursion are as follows: (This is valid for diesels and gas)
2000 year through 2001 year
MAX capacity-------tongue weight
10000----------------1000
2002 through 2005
11000----------------1100
The 2000-2002 towing books only list the maximum allowable weight for the hitch/truck combo.
The 2003 -2005 towing books list the above, but also list the maximum RATED capacity of the WD hitch.
As you see, changing the axle ratio changes the amount of weight you can carry or tow. The gross weight numbers are for performance and warranty issues NOT safety.
If you put a bigger ( higher rated) hitch on your vehicle, it will not preform to the standards that Ford felt most people wanted. And it is possable that something will wear out sooner or even outright fail if you take it to the limit.
still confused! i have a kty plant x and it says i have a class V hitch. anybody got any ideas where a person could go to find out how much tongue weight a trailer really has? who would have a scal that small to measure that much?
What year is your Ex?
You could go to a trailer shop or say a commercial scale and put the stand on the scale with the wheels off the scale. That will give you tongue weight.
Go to a truck scale & get the axle weights with the trailer hooked up. Then reweugh with just the truck. difference in the weights will tell you trailer weight, tongue weight, truck weight, & gross combined weight. All for the cost of the first scale ticket. (Reweigh's are usually free within a few min.)
My 2001 2WD 7.3L is clearly marked class V with maximum rated capacity of 12,500. I never received a manual and since I was shopping boats when I bought it I specifically asked about towing capacity. The Ford dealership had no problem confirming that it was capable of routinely towing 12,500 without further modification or performance issues. They showed me an F350 dually with exactly the same hitch and motor that was rated even higher (I think it was 16k) and they explained that the excursion was capable of doing the same but that it was marked at 12,500 because of tongue weight issues and legal liability. Now maybe the dealership is full of it but they specialize in Ford trucks and at the time had two of only three X’s with 7.3’s listed in the state of FL. Either way, as long as you stay under the limits which are clearly stated on the hitch itself wouldn’t ford have 100% liability for any failure or problem it caused?
