Engine Randomly shuts off 2001 7.3
Old 07-27-2006, 05:44 PM
Aaron871's Avatar
Aaron871
Aaron871 is offline
2001
F-250
7.3 Turbo Diesel
120K
The engine randomly shuts down for a period of time.
If at idle: It shuts off and will start right back up, no problem.
If under load: It shuts off, the tack goes to 0, sometimes for a split second, sometimes for up to 4 or 5 seconds. Then it turns back on and runs as if nothing happend.
When engine braking: The tack goes to 0, the engine is off, and it turns back on after a second or 4....
What is going on here???????????????
edit: The "Check Engine" light sometimes comes on but shuts off after a restart but the OBD II says no codes are stored...
Old 07-27-2006, 05:45 PM
ATC_250SX's Avatar
ATC_250SX
ATC_250SX is offline
Camshaft position sensor, or as ford calls it camshaft synchroniser (sp?) those have the tendancy to do excactly what you speak of.
Old 07-27-2006, 05:52 PM
Aaron871's Avatar
Aaron871
Aaron871 is offline
Where is that located in the engine?
I see it for $138 from autozone...
Old 07-27-2006, 05:53 PM
ATC_250SX's Avatar
ATC_250SX
yeah its under the water pump on the front cover, right side, low, over the crank pully, one 10 mm bolt, has the timing pointer on it, and i wouldent trust it from autozone, when it comes to electronic stuff go with oem. You get what you pay for!!
Old 07-27-2006, 05:55 PM
Aaron871's Avatar
Aaron871
Aaron871 is offline
Are you saying go to the Ford dealer?
Where should I get it? Vato-zone says 2 days to ship it, not avaliable in stores.
Thanks for the fast help...
Old 07-27-2006, 05:56 PM
PSNut's Avatar
PSNut
PSNut is offline
Check out post #5 in this thread: LINK
Nut
Old 07-27-2006, 05:58 PM
ATC_250SX's Avatar
ATC_250SX
yes im saying ford dealer, i always go for oem on electrical stuff. but personal preferance. its like 208 from the ford dealer i think, i cant remember, the last one i did was awhile ago.
Old 07-27-2006, 06:01 PM
PSNut's Avatar
PSNut
PSNut is offline
The International (IHC) dealer carries them for $100. Ford varies from $175-$200.
Nut
Old 07-27-2006, 06:06 PM
PSNut's Avatar
PSNut
PSNut is offline
Here's a CPS from one of our Sponsors: LINK
Nut
Old 07-27-2006, 06:11 PM
Aaron871's Avatar
Aaron871
Aaron871 is offline
Ford dealer is $208. So is Napa. I want it by tomorrow so I'm not searching for a better deal.
Thanks all........ I guess this is a routine question around here, thanks for being so nice about it.
Old 07-27-2006, 06:17 PM
piotrsko's Avatar
piotrsko
piotrsko is offline
I myself would go to IHC (international) and get theirs. Comes in a blue oval stamped mfg by FORD, but about $100.00. do a search for "CPS" to get correct part # which I believe is 1807339C92 for a dt444. Don't tell them it is a ford, they'll laugh.
Old 07-27-2006, 08:53 PM
cwt580's Avatar
cwt580
cwt580 is offline
everyone says the NAPA ones are junk!!!!!!
