Engine Randomly shuts off 2001 7.3
2001
F-250 7.3 Turbo Diesel 120K The engine randomly shuts down for a period of time. If at idle: It shuts off and will start right back up, no problem. If under load: It shuts off, the tack goes to 0, sometimes for a split second, sometimes for up to 4 or 5 seconds. Then it turns back on and runs as if nothing happend. When engine braking: The tack goes to 0, the engine is off, and it turns back on after a second or 4.... What is going on here??????????????? edit: The "Check Engine" light sometimes comes on but shuts off after a restart but the OBD II says no codes are stored... |
Camshaft position sensor, or as ford calls it camshaft synchroniser (sp?) those have the tendancy to do excactly what you speak of.
Where is that located in the engine?
I see it for $138 from autozone... |
yeah its under the water pump on the front cover, right side, low, over the crank pully, one 10 mm bolt, has the timing pointer on it, and i wouldent trust it from autozone, when it comes to electronic stuff go with oem. You get what you pay for!!
Are you saying go to the Ford dealer?
Where should I get it? Vato-zone says 2 days to ship it, not avaliable in stores. Thanks for the fast help... |
yes im saying ford dealer, i always go for oem on electrical stuff. but personal preferance. its like 208 from the ford dealer i think, i cant remember, the last one i did was awhile ago.
The International (IHC) dealer carries them for $100. Ford varies from $175-$200.
Nut |
Ford dealer is $208. So is Napa. I want it by tomorrow so I'm not searching for a better deal.
Thanks all........ I guess this is a routine question around here, thanks for being so nice about it. |
I myself would go to IHC (international) and get theirs. Comes in a blue oval stamped mfg by FORD, but about $100.00. do a search for "CPS" to get correct part # which I believe is 1807339C92 for a dt444. Don't tell them it is a ford, they'll laugh.
everyone says the NAPA ones are junk!!!!!!
